ES-9 S/PDIF Input & Output
Moderators: Kent, os
kooka
Post by kooka » Fri Feb 21, 2020 4:41 am
Hi,
Which S/PDIF is the input, and which the output? In the diagram in the manual, the black is labelled SPDIF In and the white is labelled SPDIF Out. That doesn't seem to be consistent with the TS jacks, where the inputs have a white background and outputs have a black background.
Thanks.
Re: ES-9 S/PDIF Input & Output
Post by os » Fri Feb 21, 2020 4:46 am
White S/PDIF is out. You can see the LED shining out through the white plastic.
Return to “Expert Sleepers”
