USAMO & Scarlett 8i6 suddenly make pro tools crash
Moderators: Kent, os
kristinowherefast
Post by kristinowherefast » Fri Feb 21, 2020 10:28 pm
I had been using the USAMO plugin in Pro tools with a 1st gen scarlett 8i6 successfully, but it suddenly stopped working - now when I load a pro tools session it gets stuck. Before this issue started, the USAMO was (and hopefully shall still be) a game-changer. So far, I've been able to determine the problem relates with the scarlett being connected w/ the USAMO. In short, the USAMO plugin makes pro tools seize up when it is plugged into the scarlett interface. Here are my observations:
-I can add an instrument track with the USAMO plugin when the scarlett is not plugged in to my mac book without an issue. If the scarlett is connected, - I cannot use the USAMO plugin (or even have it active) in a PT session without it making the session seize.
-Other instrument plugins do not cause this issue.
Restarting/Shutting down, etc. doesn't do much of anything.
I've uninstalled and re-installed pro-tools, the USAMO plugin, scarlett mix control, but nothing has helped. I'm probably missing something obvious, and if that is the case, I apologize.
Re: USAMO & Scarlett 8i6 suddenly make pro tools crash
Post by os » Sat Feb 22, 2020 6:39 am
How bizarre. Are you using the latest USAMO plug-in?
kristinowherefast
Post by kristinowherefast » Sat Feb 22, 2020 5:55 pm
I ended up restoring from a previous backup (pre-issue)- so far, so good. If it changes, you'll be the first to know.
Return to “Expert Sleepers”
