FH-1 and iconnectmidi2 with iPad help.
Moderators: Kent, os
jardmonkey
Post by jardmonkey » Sun Feb 23, 2020 6:05 pm
Hello community.
I recently picked up an FH-1 used, and an iconnectmidi2 box in the hopes of using them with my iPad/iPhone.
My understanding was that by default FH-1 would output pairs of CV pitch/Gate on outputs 1-8.
I’ve got it hooked up thusly: iPad>iconnectmidi2 usb1 and iconnectmidi2 usb2> FH-1.
FH-1 shows usb led and blinking on incoming midi from the ipad(fugue machine app).
However, no CV or gate is coming out of the FH1 outputs.
I have attempted to reset to factory defaults. FH-1 is on firmware 2.3.
If anybody has any suggestions or tips on getting midi from an iPad app like fugue machine out through iconnect devices>FH-1 it would be hugely appreciated. I’m not sure if my FH-1 is faulty.
Obviously the easy route would be to pick up an FH-2, but I’d like to try what I have first.
DB
Re: FH-1 and iconnectmidi2 with iPad help.
Post by os » Mon Feb 24, 2020 3:41 am
Have you tried sending on different MIDI channels?
jardmonkey
Post by jardmonkey » Mon Feb 24, 2020 10:42 am
OS, I have tried sending on all the midi channels available In the settings in the iOS app. Even though I see the usb activity led blinking on FH-1, all the output LEDs remain solid blue.
Post by os » Mon Feb 24, 2020 11:24 am
I would erase the configuration script, if any, and reboot. Menu H-7.
jardmonkey
Post by jardmonkey » Mon Feb 24, 2020 4:21 pm
os- I will give that a shot tonight, thank you for the tips.
jardmonkey
Post by jardmonkey » Tue Feb 25, 2020 10:56 am
No go. Clearing the config scripts didn't help. I'm going to test if plugging in a plain vanilla USB midi keyboard works before I throw in the towel on FH-1. That should just work 100% straightforward yeah, should give CV and gate for pitch and note length on outputs 1 and 2...no iconnect required? Failing that, does the FH-2 work with the USB C port to connect straight to the IOS device with midi apps?
Post by os » Tue Feb 25, 2020 11:01 am
The FH-2 will connect direct to an iPad Pro (with USB C). iPads with a Lightning connector need the Lightning-USB adaptor.
Return to “Expert Sleepers”
