Cubase 9 > SW-Sync > ES-40 > ESX-8md > Hermod midi in
Moderators: Kent, os
StereoNode
Post by StereoNode » Tue Feb 25, 2020 1:41 pm
Hi,
I'm having some clocking issues at the moment, so yesterday I purchased the ES-40 and ESX 8md to drive the Hermod from my DAW.
As of right now I am using SW-Sync Pic Bellow
As an audio insert and sending it out spdif to the ES-40
The signal is getting there since the ESX-8md is lighting up, but it doesn't seem to be transmitting anything, or at least its not sending transport or any sort of midi clock info to the Hermod. I even tried running it into the octatrack instead, with still no luck (they are both set up correctly to receive both clock and transport info over midi, as before I have been doing this with the MIO)
I'm sure this is some sort of user error.. any help please? Thanks so much
StereoNode
Re: Cubase 9 > SW-Sync > ES-40 > ESX-8md > Hermod midi in
Post by StereoNode » Tue Feb 25, 2020 1:50 pm
Here is a video example
Post by os » Wed Feb 26, 2020 3:13 am
If you want to send MIDI, you need SW ES-4 Controller, not SW Sync.
Return to “Expert Sleepers”
