Stuck Notes
Moderators: Kent, os
micdrop11
Stuck Notes
Post by micdrop11 » Tue Feb 25, 2020 6:02 pm
Hello,
I'm getting the occasional "stuck" note when using the FH-2. I'm using a Arturia Keystep midi controller via USB to the FH-2, and then the 5 pin midi expander to a Roland boutique JU-06A. When playing notes and chords on the keyboard, occasionally the JU-06A will act as if it never received the gate off signal, resulting in a stuck note. I unplug the midi cable while the note is stuck, and the note remains stuck, still playing. If I bypass the Fh-2, and connect the keyboard directly to the JU-06A, it works fine with no stuck notes.
Anyone having this issue? Thoughts?
Thanks,
Mike
micdrop11
Re: Stuck Notes
Post by micdrop11 » Tue Feb 25, 2020 9:39 pm
Apologies. I found the thread on this topic. It seems like the KeyStep is the issue.
Return to “Expert Sleepers”
