G5 Tuner acting up on the disting mk4
Moderators: Kent, os
GIUFJ
Post by GIUFJ » Sat Feb 29, 2020 7:07 pm
Good evening
I have an issue with the G5 tuner algorithm.
When I have no cable patched in, the display shows A-, and the b output flashes like crazy.
When I patch in an oscillator I wish to tune, the display is a blurry mangle with no discernible letter on it. Kinda like it writes several letters all at once.
It is the only algorithm - of the ones I use- I have any trouble with.
What to do, any thoughts?
Apart from that, lovely little module:-)
cheers
/Mort
GIUFJ
Re: G5 Tuner acting up on the disting mk4
Post by GIUFJ » Sat Feb 29, 2020 7:08 pm
I updated the firmware, hoping that would solve the issue, but it didn't
Post by os » Sun Mar 01, 2020 4:23 am
Sounds like you have a lot of noise on the input. Are you trying it with a fairly pure waveform e.g. sine or triangle?
GIUFJ
Post by GIUFJ » Tue Mar 03, 2020 2:15 pm
I'm not entirely sure what the waveform is... it's coming out of MI tides. I used to be able to tune the tides, as I recall.
I've tried switching cables, so it's not that.
When I plug in my roland SE-02 the display jumps a lot until I play a note. Then, all is well. As soon as I release the note (with the cable still inserted), the display goes nuts again.
Should the tuner algorithm display an A- when there is no input? Or is it a sign, that something is amiss?
cheers
/Morten
Post by os » Wed Mar 04, 2020 2:50 am
Yes, showing A- with no input sounds right.
megarat
Post by megarat » Mon Mar 09, 2020 5:27 am
I've found that the Disting Mk.4 tuner algorithm works fine with clean waveforms, like a pure sine or triangle, but gets hung up on complex waveforms, such as anything that comes out of my Ataraxic Iteritas. When fed a complex waveform, the display goes bonkers, as if it's recognizing several different notes in extremely rapid succession.
Return to “Expert Sleepers”
