ES-9 with other audio interface
Moderators: Kent, os
lofiBathSalts
Post by lofiBathSalts » Fri Mar 06, 2020 10:26 am
Hi noob here,
I have an Scarlett 18i20 that I use to route all of my instruments/mic and have an output that then sends them to a 1/4" input on my modular. I see that there is a way to connect the ES-8 directly to my 18i20 so that I can then use the 18i20's inputs. Is there a way to do this with the ES-9 or a way I can use my 18i20 for its routing purposes while also having the ES-9 plugged in?
Re: ES-9 with other audio interface
Post by os » Fri Mar 06, 2020 10:31 am
If you're on mac you can set up an Aggregate device in the Audio MIDI Setup utility.
Your best option though is probably to use the 18i20's ADAT ports and an ES-3/ES-6.
lofiBathSalts
Post by lofiBathSalts » Fri Mar 06, 2020 10:50 am
I don't have a mac, but the ES-3 and ES-6 seems like a good alternative! It seems like I can add the ES-5 if need and that should cover everything.
Return to “Expert Sleepers”
