Delay gates in Silent Way?
Moderators: Kent, os
morbank
Post by morbank » Sun Mar 15, 2020 1:41 am
Is it possible to adjust the timing for an individual gate in Silent Way?
Re: Delay gates in Silent Way?
Post by os » Sun Mar 15, 2020 3:55 am
No, but what's the bigger picture here? There may be some way to achieve what you need.
Monofunk
Post by Monofunk » Sun Mar 15, 2020 4:01 am
You can use track offsets and device delays inside your DAW to achieve this. What software are you running Silent Way in?
morbank
Post by morbank » Sun Mar 15, 2020 11:24 am
I use ES-40, ESX-8GT, Silent Way through Live 10 with a small Eurorack setup for 6 drum voices. Curiously my hi-hats voice (regardless of what module(s) I use) sound consistently late. I was hoping to find a way to delay the the other 5 voices to try and compensate for the lag. Monofunk, do you know of a way to do this in Live?
morbank
Post by morbank » Sun Mar 15, 2020 12:13 pm
I found the "Delay Compensation/Track Delay" features in Live and am testing them out now...
Monofunk
Post by Monofunk » Sun Mar 15, 2020 1:25 pm
Is the hi-hat voice a digital module? Maybe it's latency.
Yes you can try adjusting the track delay by a positive or negative amount. You could also adjust the MIDI data that you are feeding the Silent Way plugins and offset those notes to compensate for the hi-hat voice.
morbank
Post by morbank » Sun Mar 15, 2020 2:06 pm
I am using the WMD Crucible module which is digital. How might latency be a factor?
I am using 6 notes (one for each drum sound) on one MIDI channel. Is there a way to adjust the MIDI data for one note in Live?
morbank
Post by morbank » Sun Mar 15, 2020 2:14 pm
I should also mention, I have a track in Live with sample of a click playing a 16 note pattern that I am using to test the Crucible hi-hat latency against. The click track sounds perfectly on time with all the other eurorack drum sounds, and I can get the Crucible hats to sound like they are exactly lined up, but when I mute the click track the Crucible hats sound off/late. Even with different track delay settings in Live. It’s very odd.
Monofunk
Post by Monofunk » Sun Mar 15, 2020 5:35 pm
There's going to be a delay between the time the trigger is received and when you hear the sound. I'm not sure how significant this is with that module.
You could make a separate MIDI track in Live routed to the same destination and use it to sequence that one MIDI note.
morbank
Post by morbank » Mon Mar 16, 2020 11:50 pm
I was using an expression pedal with the Crucible (hi-hat) modules decay CV input and it turns out it was adding an offset to the decay and making the sound longer. When I take the pedal out of the patch the offset goes away and the timing becomes tight. I don't know why but when the decay is set to anything but the shortest setting it makes the hi-hats sound late!?! Especially on a 16th note pattern. Strange.
Monofunk
Post by Monofunk » Tue Mar 17, 2020 2:13 pm
Maybe WMD will have answers about this if you ask them.
morbank
Post by morbank » Tue Mar 17, 2020 11:22 pm
Good idea. I'll shoot them an email.
Return to “Expert Sleepers”
