FH-2 Din in Clock with Elektron Cycles
Moderators: Kent, os
smurf
Post by smurf » Sun Mar 15, 2020 7:51 am
Hi,
I have an Elektron Cycles attached to Din in of the FH-2 expander (using the midi trs adapter from out from the Cycles). I am trying to pass the clock out from the Cycles atm - but can't see the FH-2 receiving clock this way. If I connect the usb out from cycles to usb in on FH-2 the clock is transmitted. I tried attaching a keystep to the din in on the FH-2 expander but cant see any midi input at all - if I attach the keystep to the usb, I can see midi is coming in on the FH-2. I checked the coonections " pin 1 of the breakout's header (GT1) corresponds to pin 1 of the FH-2's header (GT3)" - and its all correct.
How can I pass clock in via Din in on the expander?
Re: FH-2 Din in Clock with Elektron Cycles
Post by os » Sun Mar 15, 2020 8:03 am
The ribbon cable that connects the FH-2 to the breakout has two rows of 4 pins. Make sure you're using the same row at each end.
smurf
Post by smurf » Sun Mar 15, 2020 8:42 am
Hi Os - Just checked - its on the same row at both ends.
smurf
Post by smurf » Sun Mar 15, 2020 8:59 am
....I haven't attached a power cable to GT2 on the din expander.
Post by os » Mon Mar 16, 2020 3:48 am
You don't need one. Have you been able to test the DIN MIDI output of the Cycles with another MIDI device?
smurf
Post by smurf » Thu Mar 19, 2020 8:08 am
yep cycles midi out to tr-08 works OK
smurf
Post by smurf » Thu Mar 19, 2020 8:28 am
Should it just automatically pick up clock on the din in - do I need to set anything first? Clock from usb goes to output 7 already.
Post by os » Thu Mar 19, 2020 8:29 am
Yes, it should just work. Any incoming MIDI should appear at the bottom of the screen, clock or otherwise.
smurf
Post by smurf » Thu Mar 19, 2020 9:29 am
Post by os » Thu Mar 19, 2020 9:33 am
No, the ribbon cable is wrong. Pin 1 at the FH-2 end is the end nearest the power connector.
smurf
Post by smurf » Thu Mar 19, 2020 9:46 am
Hi
I'm confused -from the manual "the header pin-out is as follows(pin 1 is closest to the 'GT3' text)". As far as I can see - on the FH-2 the GT3 text is nearest the top pin....
Post by os » Thu Mar 19, 2020 9:49 am
Yes, that's correct.
smurf
Post by smurf » Thu Mar 19, 2020 9:51 am
Top pin on the FH-2 (near GT3 text) is connected to pin closest to to GT1 text (left when looking at back) on expander
smurf
Post by smurf » Thu Mar 19, 2020 9:56 am
So in the image the top pin is attached to the right pin (looking from back) of the expander. They are both opposite the red stripe of the ribbon....
Post by os » Thu Mar 19, 2020 9:57 am
Pin 1 on the expander is furthest from 'GT1'. The pin actually has a little '1' next to it.
smurf
Post by smurf » Thu Mar 19, 2020 10:01 am
OK - that makes sense - thanks!
smurf
Post by smurf » Thu Mar 19, 2020 10:03 am
Sorry my eyesight is not that great!
Return to “Expert Sleepers”
