USAMO Clock Command Specs
Moderators: Kent, os
CamAdair
Post by CamAdair » Tue Mar 24, 2020 12:47 pm
Does the USAMO receive and send Start, Stop, Continue, and Song Position Pointer messages?
Is it able to run from printed audio code and not only the plugin?
Will it run DIN Sync machines?
If I put a MIDI through splitter box after it would it cause any problems multiplying the clock?
Re: USAMO Clock Command Specs
Post by os » Tue Mar 24, 2020 1:54 pm
It sends all MIDI messages.
If you capture the plug-in output, you can replay that to the USAMO, but in practice that's unlikely to be convenient.
No.
If it's a dumb splitter (just an electrical connection) it won't degrade the clock. Any MIDI patchbay/splitter that contains any processing may affect the timing.
Return to “Expert Sleepers”
