fh-1 and fhx-8cv
Moderators: Kent, os
mbroers
fh-1 and fhx-8cv
Post by mbroers » Tue Mar 24, 2020 2:26 pm
Hi, I've been using an FH-1 without issue for a while and decided to get the expander, FHX-8CV, which I believe is a supported setup.
I have the expander hooked to power, and the expansion cable is connected from GT2 on the FH-1 to the GT1 expansion IN on the FHX8CV, when I boot it just sits for a minute and does the red light flashing.
I updated the firmware to the latest on the FH-1, same issue. Any suggestions?
Re: fh-1 and fhx-8cv
Post by os » Wed Mar 25, 2020 4:34 am
The FHX-8CV will indeed flash, which indicates it's not in communication with an FH-2. After that though it should still be in a state where it receives changes from the FH-1.
What MIDI are you sending to the FH-1 to generate output from the expander?
mbroers
Post by mbroers » Wed Mar 25, 2020 8:51 am
I assumed that the flashing red lights meant it wouldnt work and didnt even progress into testing further.
I will see if it just works despite this and follow up, thanks!!!
mbroers
Post by mbroers » Wed Mar 25, 2020 11:00 pm
yep that was it. works great!
Return to “Expert Sleepers”
