FHX-8GT not working
Moderators: Kent, os
GordonAbbott
FHX-8GT not working
Post by GordonAbbott » Sat May 02, 2020 12:04 am
I'm using this with an FH-2. Just got the 8GT for gates/triggers, but I can't get it to work. A few things...
FH-2 works fine
Firmware version 1.8.2
Power cables are connected
Jumper 3 is on for the 8GT
Expansion connector cable is connected with red stripe down on both ends
Through the configuration web utility I set up trigger 1/1 to be midi channel 2, note 60. Upload and download to make sure it seems to have taken. All fine. But hit note 60 on my Keystep and nothing. I set up trigger 1 the same way and output 1 on the FH-2 triggers fine. I also connected output 1 from the 8GT to a percussion module just in case the light on the socket wasn't working but I'm getting nothing at the percussion module end either. Tried a couple different outputs on the 8GT as well as different midi channels.
Also should note that when I hit note 60 on my Keystep the front panel of the FH-2 does read note 60 on.
The FH-2 I bought used but he FHX-8GT is brand new.
Any help would be greatly appreciated. Working on writing my own software to control my modular and was looking forward to 8 gate/trigger outputs to play with.
os
Re: FHX-8GT not working
Post by os » Sat May 02, 2020 5:36 am
If jumper 3 is on, the 8GT will respond to FH-2 output numbers 81-88, or GT2/1 and up in the config tool.
I would remove the jumper, so you're using GT0/1 and up. You can then also use 'test FHX-8GT' from the FH-2 menu.
Lillium
Post by Lillium » Sat May 02, 2020 7:09 pm
Having same problem like above, but have updated to 1.9.
heh I Feel stupid :/
I did the test and it send out pulses on FHX-8GT. But cant get it to work with anykind of signal. Very confusing working with the Web editor.
Could anyone make this clear, can the FHX-8GT only output trigger/gate for a specific Note number on a specfic midi CH? Would be amzing if i dont need to make one gate pattern and one midi note pattern in my DAW. Maybe 2 of FHx-8CV is a better and flexible option for melodic tracks?
midi Ch1
FH-2 out:
1 - Pitch
2 - velocity
3 - after touch / or any CC
FHX-8gt out:
1 - gate from midi CH1
Midi ch2
FH-2 out:
4 pitch
5 velocity
6 after touch / or any CC
FHX-8gt
2 - gate from midi CH2
Midi ch3
FH-2 out:
7pitch
8 velocity
FHX-8gt
3 - gate from midi CH3
And maybe then a clock, start/stop
7/8 on fhx-8gt.
would be good with a video how to install the fh-2 with each of it expanders with a typical DAW config :) Have one FHX-8CV on order but waiting for delivery.
Really would be so much fun to get this working like this now atleast :)
had a Shuttle controll before and it was pretty straight forward. But think the Fh-2 is far more superior if i can get to work.
os
Post by os » Mon May 04, 2020 3:48 am
No, you can use it as the gate output from a MIDI/CV converter. To do so, set the 'Base Gate' parameter of the MIDI/CV converter.
GordonAbbott
Post by GordonAbbott » Mon May 04, 2020 10:48 am
Thanks Os! I realize now that I somehow looked at the CV expander manual instead of the gate expander manual which is why I set jumper 3. Works just fine now. Back to writing software!
Lillium
Post by Lillium » Wed May 06, 2020 3:44 pm
Hehe :hihi: it was the base output i didt do right thanks os
Works perfect now :sb:
Schanke
Post by Schanke » Mon Aug 10, 2020 3:05 pm
My FHX-8GT also doesnt work. I first connected wrongly the 10pin cable to the to esx out on the fh-2. hope that didnt fry my fhx-8gate.
it now blinks after a few seconds red on all outs of the module. the fh-2 seems to be fine. eieieieieieiei
no connection possible to the fhx-8gate. i still have problems unterstanding how to route the gate out via the config tool.
os
Post by os » Tue Aug 11, 2020 2:21 am
If the expander flashes all outputs five times about 10 seconds after boot, that indicates no connection to the FH-2. Which means either the cable isn't connected properly, or one of the modules has a fault.
Return to “Expert Sleepers”
