disting EX change of default MIDI mapping in v1.2
Moderators: Kent, os
Umcorps
Will patch for food
Post by Umcorps » Fri May 22, 2020 11:51 am
os wrote:
Fri May 22, 2020 5:41 am
* Changed the default MIDI CC mapping for single algorithms to start at CC #7.
That's broken a lot of stuff for me :(
Is it possible for me to make an alternative mapping file that restores the previous arrangement (starting at CC1) and have that used as the local default?
Re: disting EX firmware announcement thread
Post by os » Fri May 22, 2020 12:04 pm
You've been pretty busy if that's broken "a lot" of stuff - the module's only been out a couple of weeks! :)
You can certainly edit the mapping and save it. You can set that as a start-up mapping, but it will be wiped with defaults when you switch algorithm, so you'd have to load it again.
Umcorps
Will patch for food
Re: disting EX change of default MIDI mapping in v1.2
Post by Umcorps » Fri May 22, 2020 1:56 pm
I know I've been busy! I made a TouchOSC control surface to manage every aspect of the EX. And the TouchOSC editor is so lame that its impossible to do any kind of batch editing. So while in a sensible editor it it would be trivial to do a batch edit to minus 6 from each CC value, in the editor I'm stuck with I have to edit every single entry by hand. Which will be the opposite of trivial.
I think my only option is to do just that. But you've got to promise me you're not going to do this again :foul: :lol:
Post by os » Sat May 23, 2020 3:38 am
I have no plans to do it again. The reasoning behind it was that
a) it's easier to remember parameter number == CC number
b) if you connect a keyboard with a mod wheel, which sends CC #1 by default, you don't end up accidentally changing a parameter.
Umcorps
Will patch for food
Post by Umcorps » Sat May 23, 2020 3:47 am
Don't suppose you could make it a selectable option in future releases? Default = 7 with an option of 1?
Post by os » Sat May 23, 2020 9:46 am
Try this.
Umcorps
Will patch for food
Post by Umcorps » Sat May 23, 2020 9:53 am
:hail: You're a star
LDT
The Modu-Lars
Post by LDT » Sun May 24, 2020 4:08 am
Support Level: Ninja Master
-Lars
Return to “Expert Sleepers”
