es-9 fresh install noise
Moderators: Kent, os
dlf
Post by dlf » Sat Jun 06, 2020 12:26 pm
hi there,
just installed my new es-9 out of the box in a doepfer A-100MC case,
connected it to my 2018 macmini and inserted headphones.
installed the es-9 config tool, version says 1.1.1
opened ableton, selected es-9 as input and output device.
am receiving a very loud noise on all input channels.
same noise also audible on headphones, with or without usb connection to the computer.
any ideas ?
thank you, gideon
Re: es-9 fresh install noise
Post by os » Mon Jun 08, 2020 4:24 am
The A-100MC cannot supply enough power to the ES-9. You'll need a better PSU.
fruitsnake
Post by fruitsnake » Mon Jun 29, 2020 7:05 pm
Hi,
I just got my ES-9 and I am having this same issue - all inputs make a high pitched sound and don't pass audio. The high pitched sound can be routed to the outputs via the configuration tool and can be recorded in my DAW. Audio from my DAW (Reaper) will play out of the ES-9, but no audio will go in (however, incoming audio is displayed accurately by the LED in the jack). I'm running Windows 10, got the v1.1.1 firmware. Here's what I've tried:
4ms Pod40 powered case, ES-9 is the only module in the case;
uZeus powering the ES-9 only
Both situations produce the same result. Do I need a different power module, and if so, which one?
Post by os » Tue Jun 30, 2020 2:08 am
A uZeus should be plenty powerful for the ES-9.
Have you installed the driver?
fruitsnake
Post by fruitsnake » Tue Jun 30, 2020 8:50 am
Yes i have the driver installed and it seems to connect to my computer just fine
dlf
Post by dlf » Tue Jun 30, 2020 9:54 am
I can say for me, installing the es-9 in a bigger case with more power did the trick. (a doepfer A-100P6 case w PSU3)
fruitsnake
Post by fruitsnake » Tue Jun 30, 2020 10:47 am
The person i bought it from said they had it in that same doepfer case and it was working for them. It does seem strange that i couldn't get it to work using a uzeus tho since the specs say it should be fine
fruitsnake
Post by fruitsnake » Wed Jul 08, 2020 6:28 pm
Ok, here's the update... the uZeus (and the Pod 40x for that matter) probably will power the ES9 just fine, unfortunately my ES9 is just totally busted. I brought it to Control in Brooklyn and had them test it out for me, and no matter what they did all the inputs still made a high-pitched screech noise, so it looks like I'm gonna have to send it in for a repair.
Return to “Expert Sleepers”
