firmware 4.17 issues
Moderators: Kent, os
Post by ignatius » Sun Sep 13, 2020 10:16 pm
4.17 is buggy as hell for me. doesn't really work. crashes the module. also, doesn't allow paging through parameters. the Z knob still works but pressing it doesn't page through the parameters.
os
Re: disting mk4 firmware announcement thread
Post by os » Mon Sep 14, 2020 2:16 am
Splitting to a new thread.
os
Re: firmware 4.17 issues
Post by os » Mon Sep 14, 2020 2:18 am
Could you expand on what crashes and when?
Some algorithms use Z for something else e.g. reverbs use it as freeze. You can still select parameters with S.
Post by ignatius » Mon Sep 14, 2020 1:45 pm
i was exploring the granular pitchshifter and only had access to the first parameter. couldn't page through the other parameters. i tried to change algorithms and it freaked out and would jump around in the algorithm list as i turned the knob. then all the lights in the display got brighter and it did a kind of pulsing thing and freezed up. I rebooted and tried again but got same results.
i put v4.16 back on it and it now works as it should.
edit: i should add that i did reinstall v4.17 thinking maybe something went wrong w/the install and wiping it and starting again would help but it didn't.
os
Post by os » Tue Sep 15, 2020 2:02 am
4.17 adds the freeze function to the granular pitch shifter, so you'll have to change parameters with S.
Post by ignatius » Tue Sep 15, 2020 1:27 pm
push/turn S right? well, i'll give it another go but didn't work out last time. will report back.
Post by ignatius » Wed Sep 16, 2020 9:23 pm
sucess this time! i think i maybe was a little impatient with the previous install and was jumping around trying to get through parameters and that caused some freaking out of the module. seems fine now that I go slower through accessing the parameters via the S knob.
tldr - user error ;)
qwoned
Post by qwoned » Thu Sep 24, 2020 9:05 pm
the Y input seems non-responsive for the K-1 through K-5 algorithms. It will only change wavetables manually via S knob. Anything I can do to fix this?
os
Post by os » Fri Sep 25, 2020 2:15 am
Y doesn't change the wavetable - it changes the wavetable position, same as parameter 1, not parameter 0.
Is that the confusion?
qwoned
Post by qwoned » Fri Sep 25, 2020 2:31 am
Perhaps, yes. Do you mean the phase position within a single wavetable?
To be clear, changing individual wavetables can only be manually controlled? If so, would it be possible in a future firmware update to use a control voltage input for changing wavetables?
os
Post by os » Fri Sep 25, 2020 2:40 am
Yes - or via MIDI.
Changing the wavetable is not instantaneous - it would be quite glitchy changing it via CV. Is what you want a kind of two-dimensional wavetable lookup?
Could you achieve what you want by combining your wavetables into one giant wavetable?
qwoned
Post by qwoned » Fri Sep 25, 2020 2:58 am
Maybe I'm still misunderstanding, sorry. In your video demo for algorithm K2, wavetables (i.e. different single-cycle waveforms) are 'scanned' via LFO into Y input without glitchiness, no? I was unable to achieve this result when I tried myself. I had individual WAV files for each waveform, rather than one concatenated file.
os
Post by os » Fri Sep 25, 2020 3:06 am
In the terminology of the disting a 'wavetable' is a collection of single cycle waveforms. So Y scans through the waveforms, smoothly.
How big are your waveform WAVs? Perhaps they're too big, and the disting can only load one.
qwoned
Post by qwoned » Fri Sep 25, 2020 3:16 am
Okay, I thought so. All 63 WAV files in my 'wavetables' folder are 556 bytes. Should I rather include a single concatenated WAV instead of these? If so, this requires a playlist_wavetable.txt file, correct?
Thanks so much for your help with this.
os
Post by os » Fri Sep 25, 2020 3:19 am
That should be fine - no need to concatenate or make a playlist.
They do however need to be in a folder, inside 'wavetables'. See user manual page 85.
qwoned
Post by qwoned » Fri Sep 25, 2020 3:35 am
Ah, this was the issue: I neglected to nest! I had microSD > wavetables > 00-63.WAV. I appreciate the clarification.
qwoned
Post by qwoned » Fri Sep 25, 2020 3:55 am
One more question: If each WAV is 533 bytes, what is the maximum number of individual single-cycle WAVs the mk4 can scan within a folder?
os
Post by os » Fri Sep 25, 2020 4:00 am
The max is 29000 samples. A 533 byte WAV probably contains about 250 samples, but you could easily check that.
os
PS there's also a 100 file limit.
qwoned
Post by qwoned » Fri Sep 25, 2020 4:17 am
100 file limit for each nested folder? Or for the entire microSD?
os
Post by os » Fri Sep 25, 2020 4:25 am
100 files in each folder.
Return to “Expert Sleepers”
