When You say you are hitting load on the fly - you too are presetting the load on/leave/load off switch then hitting load yes?To be honest I still haven't got my head around the leave mode. I tend to use it as a creator of happy accidents. Often I'm not sure what to expect when I hit load on the fly during a set
I was hoping to only flick an individual stages Load On/Leave/Load off switch on the fly whilst sequence is running
without needing an explicit Load. If you think the preload on position should help me achieve this - then i still have an issue.
Back in manual mode, if (with a LoadOn selected) I I hit Load with the preload switch set off, the preload led stays stays on
until i hit load again or shift. Now shouldnt that onl;y occur when preload switch is on ?
Just too illogical for me.
Thanks for the time as always.
