Hi
Didnt want to clog up your asv thread but id love to know how you can make a variable shape cv using those two modules. that would be so cool. so i could use a sequencer to have a different shape per step? thats amazing.
thanks so much, Ben
Shape cv with dual VCA and SVF?
- Paradigm X
- Super Deluxe Wiggler
- Synthbuilder
Re: Shape cv with dual VCA and SVF?
Try this. I think this should work.
Take the LP output of the SVF to IN1 on the DVCA. Take the HP output of the SVF to IN2 of the DVCA. Turn the GAIN1 and the GAIN2 on the DVCA to their mid points. If you have a DVCA-X then set both VCA channels to LIN. The OUT2/MIX socket on the DVCA is your new SVF shape output. Right now, you will be hearing the same sort of sound as the NOTCH output on the SVF, that is, the mid point of the shape control on the ASV.
Patch both CV1 and CV2 inputs of the DVCA to a mult to connect them together. Set the CV1 pot on the DVCA fully anti-clockwise, and set CV2 fully clockwise. The mult can now be connected to your CV source that you wish to control the SVF's new shape function. Positive CVs should make the sound tend towards HP, and negative CVs should make it go towards the LP. You can reverse this simply by swapping the positions of the two CV controls on the DVCA.
Tony
Tony
- Paradigm X
Awesome, thanks so much for that ! ill give it a try tonight.
I currently use my dvca as an output module, criminally underused as a volume control, so will definitely have to get the ouput module when i get paid.
Many thanks, Ben
Many thanks, Ben
- Paradigm X
well it works wonderfully, thank you again! having all sorts of fun with this. i really liked morphing between lp and bp instead of hp but all variants are great. thanks again!
- Synthbuilder
And like I said nearly 20 years ago...
