Journeyman for Eurorack
Synthbuilder
Post by Synthbuilder » Mon Mar 16, 2020 9:46 am
The Journeyman is now available in the smaller format.
The circuit is mostly the same as the 5U Journeyman except that I have used the improved drive control from the 5U DLF instead of the original. That is, like the DLF, turning up the drive control doesn't change the output volume.
More information:
http://www.oakleysound.com/Journeyman-e.htm
Builder's Guide and sound samples should be ready by the end of the week.
All being well the next Eurorack conversion will be the DLF, also in 6HP.
Tony
Synthbuilder
Re: Journeyman for Eurorack
Post by Synthbuilder » Tue Mar 17, 2020 10:36 am
The Builder's Guide for the Journeyman is now online.
Sound samples will be up later this week.
Tony
efluon
Post by efluon » Fri Oct 23, 2020 4:21 am
for easy mousering, here is my project, without panel elements and headers.
efluon
Post by efluon » Mon Nov 30, 2020 5:47 am
So, I built my dual version.
I really appreciate the PCB-Quality. HASL finish (I do hate soldering ground connections on those pretty ENIG-panels that are not so fresh). Silkscreen has readable font, always fully printed (no lost letters, or 0=8), part numbering is oriented on PCB (not schematics).
I'm a new fan!
I was slightly unsure about normalisation / ground for making a dual version, Tony answered my questions very quickly and with good explanations. (I normalised CV from left side to right, and left Out to right In)
Sounds splendid. Also has my first Schaeffer panel, looks great. Have to share.
waldenpotato
Post by waldenpotato » Wed Dec 02, 2020 12:44 pm
This is cool. What color did you use for the front panel? I'm curious if there is an easy way to build this without having to modify the circuit boards.
efluon
Post by efluon » Wed Dec 02, 2020 7:21 pm
This is bronze elox.
I was conflicted as well, and unsure if i might want to use it separately..but then the panel is expensive as is, two singles much more, and i was too lazy to make ugly fr4 or freestyle alum panels. Also this was an indulgence. And i am happy, this is a very nicely resodriving „bandpass“.
So, the normalization would be more difficult without cutting traces, as all are normalized to 0V.. which you could in theory do, by working on the thonkiconns. That was too involved for me though, and the mod of the pcb is very easy.
