DLF and MOSPhaser success...
- diode_destroyer
- Common Wiggler
Took me about 8 months or so, but finally finished these! I would recommend using short bat switches for them though as space for knob turning is tight; I used these: https://www.mouser.com/ProductDetail/Da ... d8KURHU%2F. Also on the MOSPhaser I hooked the bi-color (red,green) led up opposite the suggested way as I thought having the led light green as it sweeps up in freq and red for down is more in accordance with the doppler shift
. Love the modules. Thanks Tony!
- Synthbuilder
- Super Deluxe Wiggler
Re: DLF and MOSPhaser success...
Always nice to see finished modules.
And I'll add the switch information to the next update of the parts guide. They look like the very same ones as Thonk sells that I currently recommend but I didn't know their full part number until now.
The red/green thing is something I struggled with for a while. If you think in terms of traffic lights and stop/go you tend towards the idea that red is slowing and green accelerating. But red is also universally used to represent positive voltages. Argh... In the end the engineer in me won out and I use red for positive and green for negative, but it still doesn't sit well.
- Common Wiggler
MOSPhaser's on my "to build" list, thanks for the tips!
WTB:
Veils (pre-2020)
TipTop stackable cables (cyan/yellow/blue)
FS:
Arturia Beatstep Pro (white) - £150 + shipping
Antumbra 6MIX - £75 + shipping
Kassutronics Slope 2 - £110 + shipping
Veils (pre-2020)
FS:
- Leverkusen
I never asked but also struggled with it and guessed there had to be a technical explaination for this. Great to finally get bit of insight on this. My spontaneous reaction now was that negative should be blue then - you know, like with temperature...Synthbuilder wrote: ↑Fri Nov 13, 2020 4:41 amThe red/green thing is something I struggled with for a while. If you think in terms of traffic lights and stop/go you tend towards the idea that red is slowing and green accelerating. But red is also universally used to represent positive voltages. Argh... In the end the engineer in me won out and I use red for positive and green for negative, but it still doesn't sit well.
- diode_destroyer
- Common Wiggler
Actually blue stars (or any black-body type radiation things) are the hottest, and red is cooler...Leverkusen wrote: ↑Fri Nov 13, 2020 5:17 am... My spontaneous reaction now was that negative should be blue then - you know, like with temperature...![]()
Also it took me a long long time to work out that the MOSPhaser is based on the ehy naughty stone, and I still can't figure out how the CD4009 works here. Good times.
Last edited by diode_destroyer on Fri Nov 13, 2020 9:06 am, edited 1 time in total.
- Leverkusen
I am not very familiar with astrology but ist seems that stars are quite different from water taps then...what a strange world we live in. Apart from that I agree that blue LED's fit better with aluminium panels. Perhaps because metal is just as cool as blue is, kind of. The same with jazz by the way...diode_destroyer wrote: ↑Fri Nov 13, 2020 9:01 amActually blue stars (or any black-body type radiation things) are the hottest, and red is cooler...Leverkusen wrote: ↑Fri Nov 13, 2020 5:17 am... My spontaneous reaction now was that negative should be blue then - you know, like with temperature...![]()
All 6 in 1, 0.5*(bakers dozen - 1) in the other I guess though... I do want to find a red/blue bi-color led for it though, as I think blue LEDs are nicer than green ones.
- Common Wiggler
I like the Happy Nerding 3xMIA convention which uses blue for minus and green for plus. Seeing blue instead of red sort of changes my expectation about what each colour means.
WTB:
Veils (pre-2020)
FS:
Veils (pre-2020)
FS:
