Delay transistors
oozitron
solder fume huffer
Delay transistors
Post by oozitron » Fri Jan 01, 2021 11:29 pm
The analogue delay (ADR-30) calls for two BC547C transistors.
Would BC547 CBU transistors work ok? (couldn't find info on "C" vs "CBU" anywhere and probably wouldn't understand it anyway)
thanks!
Andrew
Never want to come down, never want to put my feet back down on the ground
Flounderguts
Re: Delay transistors
Post by Flounderguts » Fri Jan 01, 2021 11:47 pm
They're the same thing. The "C" refers to the grade of the transistor. The "BU" tells us that it is from ON Semiconductor (rather than, say, Motorola) and that it came in "bulk" packaging. Other suffixes from ONSemi include "TFR" and "TA." They will all work exactly the same way in your ADR-30.
Have fun!
Flounderguts
oozitron
solder fume huffer
Post by oozitron » Fri Jan 01, 2021 11:57 pm
Thanks Flounderguts :-)
This is weird because I was *just* looking at the "what could you talk about for 30 min" thread and saw that you listed metallurgy. My dad got his degree in metallurgy and worked for a "specialty metals" company that had molybdenum in most of their products. When they got a huge extrusion press my dad was supervisor of that part of the plant. I worked summers there during college, making pure moly hex nuts for industrial furnaces.
anyway, thanks again and Happy New Year!
Andrew
Synthbuilder
Post by Synthbuilder » Sat Jan 02, 2021 6:04 am
The ADR30 uses BC549C and BC559C transistors. There are no BC547C used, although they would probably work just fine in place of the BC549C.
Tony
oozitron
solder fume huffer
Post by oozitron » Sat Jan 02, 2021 12:23 pm
Yeah, I was looking at my spreadsheet wrong! If I had to pay myself for all the time I spend keeping track of parts and ordering more and such, I'd never be able to afford this hobby!
Andrew
