eljay wrote: ↑Mon Feb 22, 2021 5:20 am
The overlay thickness in the file is 2mm not the 1.5mm you mention at the bottom of the web page description...
Sorry. That's a mistake. It should be 2mm. I wish it was 1.5mm as it would be better I think. I've never had the courage to ask Schaeffer whether they would do a 1.5mm one.
Just to confirm the hole diameter for the Power Switch is incorrect and is just a place marker, the hole diameter needs to be amended to the size required by the power switch selected.
It's not so much incorrect but, as you say, just a marker for your chosen switch. Power switches come in many shapes and sizes and availability (especially at the moment) varies from country to country. And it will also depend on whether the builder is using a DPST or SPST which is determined by the type power supply they are using.
I have identified a Multicomp switch from Farnell, part number 1634642 that requires a 20.2mm diameter front panel hole. This is a clip-in type switch and will fit a panel up to 3mm thick hence it would be necessary to drill a bigger hole in the rack enclosure front panel of 24mm to provide clearance, which seems quite big. Should I look for something smaller?
I used a smaller one. Rapid part: 75-0057. Like that Farnell one it's only suitable for the internal mains transformer, or a very beefy single phase wallwart.
I did have to make the hole behind the overlay slightly bigger than the hole in the overlay to accommodate the spring clips.
