Can I mix 5U modules with eurorack modules?
waldenpotato
Post by waldenpotato » Sun Feb 07, 2021 4:27 pm
Can the Oakley 5U modules be used alongside eurorack modules - Oakley or other brands? I know that the power supplies would be different, but I’m not familiar enough with the 5U standard to say if they’re compatible.
I like some of the old designs and being able to build with through-hole components.
waldenpotato
Re: Can I mix 5U modules with eurorack modules?
Post by waldenpotato » Sun Feb 07, 2021 10:30 pm
I think I've answered my own question. I think that it is *ok* to mix the two formats as long as their "signals" are in the same standard. For example, if the audio signals are both 10V peak-to-peak, then things are okay. Another example would be gate signals - if both handle 5V gate signals then everything is okay.
I know this question is probably more appropriate in another sub-forum but I ask it here because I'm mostly interested in the Oakley 5U modules.
Synthbuilder
Post by Synthbuilder » Mon Feb 08, 2021 3:38 am
Aside from the power supply differences all my modules whether they are 5U or Euro are compatible with each other.
There is the potential (pardon the pun) that a 5U module powered from +/-15V may cause issues to a less robustly designed eurorack module running from +/-12V. That is, a 5U module may put out a signal (CV or audio) that exceeds 12V and this may cause a problem to some eurorack modules. However, most 5U modules feature some sort of current limiting resistor in series with the output which should prevent any serious issues.
Tony
ratchet
Post by ratchet » Mon Feb 08, 2021 4:04 am
I have a 5U and a Eurorack case next to each other and patch between them. Each case operates on its own power supply.
You may find that some attenuation is required depending on the modules but that isn't unusual even within the same standard.
waldenpotato
Post by waldenpotato » Wed Feb 10, 2021 11:01 am
I just thought of another question related to this:
If I have the 5U modules in a separate case than the eurorack modules, can I patch between them without any issues? They will have different power supplies. Looking at the Krisp1 power supply products and the Oakley power supply I see a place for banana plugs that allow you to share grounding between cases. Is this necessary and is it possible to interface the grounding like this with some eurorack power supply that doesn't offer a grounding plug like this.
Synthbuilder
Post by Synthbuilder » Wed Feb 10, 2021 1:12 pm
This shouldn't be a problem. In fact I do it as I have a small 5U and Eurorack system and regularly patch between them.
The moment you make the connection between one system and another with a standard patch cable you will tie the 0Vs of the two systems together. It is best that this 0V connection is as low a resistance as possible to reduce any unwanted crosstalk between modules and signals. The more patch connections you make the stronger this 0V connection will be and for most people they won't have a problem. However, in some cases it is preferable to tie the 0Vs together more strongly and this can be done with an extra dedicated 0V connection made with a much thicker cable. This is what the banana sockets allow. Some systems use even bigger connectors for even better performance. But again, not everyone needs it.
Purveyor2
Post by Purveyor2 » Sun Feb 14, 2021 9:13 pm
I’m having issues patching between an MOTM case and my Oakley case. Different power supplies, both just running +/-15v. The Oakley stuff doesn’t respond if patched from the other case and the oscillators stop making noise (or my multimix does). Any ideas to remedy?
EATyourGUITAR
has no life
Post by EATyourGUITAR » Sun Feb 14, 2021 9:28 pm
this is pretty much almost impossible unless one of your patch cables has a broken shield. do you have plastic jacks on any modules? are both cases mains earth referenced all the way to the audio jack shield where you patch the cable? you can get out a multimeter and test the DC and AC voltage potential between shields on the MOTM case and shields on the Oakley case. If you get 0v AC and 0v DC then you can move on to test DC resistance between the jack shields of the two systems. you should get less than 10 Ohms between systems if they are both mains earthed and plugged into the same building and the building is wired correctly. if you still have problems, check for a broken patch cable. you may have a bad patch cable that works without the shield of the cable connected at both ends if you stay within one of those systems only. patching between systems highlights the hidden problem that you have a bad patch cable.
Synthbuilder
Post by Synthbuilder » Mon Feb 15, 2021 3:57 am
If both cases are 5U, is the Oakley one built as an MU format or MOTM? If the former make sure you've read this:
viewtopic.php?f=36&t=223392
If the Oakley one has been built with an Oakley Dizzy, make sure that pin 3 of the power headers are connected to the power supply's 0V. That is, you should have four wires going back to your power supply, so both 0V connections from the Dizzy go back to the PSU's 0V terminal(s).
EYG's suggestion of a dodgy patch lead with a missing screen connector is also worth looking into.
Tony
Purveyor2
Post by Purveyor2 » Mon Feb 15, 2021 1:47 pm
Cables made at home, squareplug with Mogami. Checked a few, the insulators are all in place. Oakley case is MOTM format - Oakley power with dizzy, PA-30 line lump. I checked the 0v connections and they are proper. I can take something from the Oakley case to the MOTM case without problem but not the other way. Now the MOTM case has analogcraftsman power which comes from a dc line lump. I think I’ll look there, I recall doing some work to add a second bus board a while back...
Synthbuilder
Post by Synthbuilder » Tue Feb 16, 2021 4:14 am
Please do let us know what you find. Because I am completely lost as to why it should work one way but not the other.
Purveyor2
Post by Purveyor2 » Tue Feb 16, 2021 8:56 am
Super weird. I’m just going to build Oakley power for the synth tech case, not crazy about DC adapter going straight to the busboard with the current supply. I’ll drop you an email shortly.
