.mix .knob .replacement
Discussion and support for STG Soundlabs modules of all formats.
Moderators: Kent, suitandtieguy
proturboplus
Post by proturboplus » Sun Jan 19, 2014 11:16 am
Hi!
I like the .mix, but the colors of the knobs (eurorack) are not really my favorite ones. :hihi:
Can somebody give me the specs of these knobs in order to replace them?
I'm looking for something similar as these ones, which I have on my other eurorack modules:
http://www.smallbearelec.com/servlet/Detail?no=1192
mikecameron
Thread Killer
Post by mikecameron » Sun Jan 19, 2014 10:27 pm
Those knobs you linked to are 5/8" which will fit, but will make it SUPER cramped with cables plugged in. The original knobs are DAVIES CLONES which are 1/2" in diameter. Any 1/2" knob will work, I wouldn't put anything bigger on it.
proturboplus
Post by proturboplus » Mon Jan 20, 2014 7:55 am
Thanks for the info, so they have the same 6mm splined shaft as the doepfer ones?
(Just wondering, aren't there any black Davies clones?)
mikecameron
Thread Killer
Post by mikecameron » Tue Jan 21, 2014 3:36 pm
there are, just a separate item number. depending on if you want the ABS plastic or the Phenolic. No splined shaft! You need knobs to fit 1/4" shafts w/set screw.
http://www.smallbearelec.com/servlet/Ca ... 7&total=74
Return to “STG Soundlabs”
