.div with LFOs
oneano
.div with LFOs
Post by oneano » Thu Mar 05, 2015 6:26 pm
I use a doepfer quad lfo as my main clock and have no issues with it with any modules.
Can I use it with the .div module and get the expected results?
DonaldCrunk
pregnant with sound
Post by DonaldCrunk » Fri Mar 06, 2015 12:05 am
My .div is not really picky about what it divides, an LFO will be fine. everything works as you would expect and I've had no troubles triggering things with it.
oneano
Post by oneano » Fri Mar 06, 2015 9:07 pm
Audio signals?
det3
Post by det3 » Sat Mar 07, 2015 4:28 pm
While the .DIV was designed to operate with 0-5V signals, the input protection on it will allow it to work with audio as long as it's +/-5Vpp.
Detachment 3
Destroy what Destroys You
oneano
Post by oneano » Sun Mar 08, 2015 4:34 pm
Ok, that is good info.
I will be using it with my doepfer A-143-4
it should be a lot of fun!
Thanks.
smirnow
Post by smirnow » Thu Mar 26, 2015 7:42 am
Another question about .div . Is it possible to divide gate signals by .div? it's mean longer signals than trigger.
lvoemachine
Post by lvoemachine » Sat Mar 28, 2015 2:58 am
yes, I do that all the time.
suitandtieguy
Hammond King
Post by suitandtieguy » Sat Mar 28, 2015 2:59 am
smirnow wrote:Another question about .div . Is it possible to divide gate signals by .div? it's mean longer signals than trigger.
the output gate length is equal to the input gate length, so you can use any gate signal longer than 1/20,000th of a second or so in length.
http://suitandtieguy.com
http://stgsoundlabs.com
smirnow
Post by smirnow » Mon Mar 30, 2015 2:54 pm
lvoemachine wrote:yes, I do that all the time.
Thx For info guys!
Return to “STG Soundlabs”
