Power cable question
Dedicated forum for the MMM synth modules, both production and DIY units.
Moderators: Kent, mmm
pugix
Post by pugix » Mon May 10, 2010 8:39 pm
I'm planning on putting two DIY boards behind one panel. I use the 4-pin MOTM power connector to connect the supply. I was wondering if the Power Cable 6P-6P can be used to run power from one Mattson board to the other.
Richard
https://www.pugix.com
mmm
yummm!
Re: Power cable question
Post by mmm » Mon May 10, 2010 9:26 pm
pugix wrote:I'm planning on putting two DIY boards behind one panel. I use the 4-pin MOTM power connector to connect the supply. I was wondering if the Power Cable 6P-6P can be used to run power from one Mattson board to the other.
Absolutely.
pugix
Post by pugix » Tue May 11, 2010 6:57 pm
I ordered a couple of 6P-6P cables! Thanks.
Now I see the advantage to having both types of power connector on each board.
Richard
mmm
yummm!
Post by mmm » Tue May 11, 2010 7:18 pm
pugix wrote:I ordered a couple of 6P-6P cables! Thanks.
:headbang:
Return to “Mattson Mini Modular”
