Large system organization and patching techniques
I am "graduating" to a Doepfer monster stack (8x168hp) up from my 6x150 hp case I have now. At this point, I'll be exceeding my patch cable lengths for any sort of cross-case runs. For those of you with equally larger, or larger systems, do you have any tips or techniques when it comes to system layout. Do you take in ergonomics into account (sitting vs standing for example). Does your system follow a set signal path, or is it more sporadic?
Re: Large system organization and patching techniques
mines standing... i just grouped things into different sections, like i have the drums top left, synths top right, filters lower left, utilities/overflow bottom right and the long thin case along the bottom is a control/output section. I previously would group things so in my typical patch the cable lengths were all as short as possible (due to not having enough long cables mostly) but system is so big now that its just too hard to do this and it was a lot easier to just buy more longer patch cables and make a big mess...
- acgenerator
- Ultra Wiggler
I use the magical Muffwiggler search function to see if this question was asked a billion times already. (hint: it has)
I have a Doepfer 6x168. Base plus 12U. I don't really follow much of a plan now, I just have lots of long cables.
acgenerator wrote: ↑Sun Feb 21, 2021 7:59 pmI use the magical Muffwiggler search function to see if this question was asked a billion times already. (hint: it has)
- Pelsea
I definitely considered ergonomics in the design. The shape of the case follows the arc of my arm, the top is even with my eyes (sitting down), and the most often used controls are mostly on the desk. Combined with a decent chair, I have a very comfortable workspace. (Not shown to the left is my large studio mixer and a Mac Pro with a DAW that can be patched in if the spirit moves me.)
I don't fuss with super long patch cords--when I need to go a long way, I connect two together with one of these:
I follow this layout fairly well other than the left side which has percussion modules and a Doepfer vocoder mushed in there.
This makes it easy to create voices from the bottom up, but I’ve also got some 4 foot cables and multi along the rack edges to patch lengthwise.
It’s easy to stand and patch but with all the controllers down low I can sit and wiggle away
Be the modulation you wish to see in the world
https://www.patreon.com/join/jdanielcramer
http://queertunes.bandcamp.com
http://m.youtube.com/user/jdanielcramer
http://soundcloud.com/dcramer
- indigoid
My main system (Doepfer monster base + 12u monster case) is arranged by manufacturer because typically when I want a <thing>, I know which manufacturer I want it from.
The rest is mostly a mess.
Zap him again! ZAP THE SONOFABITCH AGAIN!
- nostalghia
I happened to have rearranged my whole system last weekend for the first time in years. Strikes me I should do that more often as a new layout provokes a different patching approach for me. But that’s another topic... my own notes unedited as I was trying to plan approach;
Reconfigure modules in order of priority, playability and most often tweaked. Start low-center and expand outwards in circular fashion. Balance with central modules which are communicating most, I.e., VCAs... Spread out utilities across. Attenuators and multiples not close to each other
Priority;
1. Sequencing, precision adder, quantizers, gates and controllers (base row)
2. Filters (third row [tilted] center, best ergonomics)
3. Envelopes (second row)
VCA VCA VCA (second row)
4. FX (fourth row center to right)
5. OSCs (second and third rows, left and right- not center)
6. Mixers (fourth row left to center)
Deviated a bit here and there with progressive elaboration while putting everything is, stuck to the plan mostly and really like the flow now. Drum system to the far left and to the right of my main system I ended up putting some modules that just don’t get too much attention but which I don’t want to part with either.
Priority;
