Do any modules or synths accept USB midi direclty (powered)?
Moderators: lisa, Kent, Joe.
twistedneck
Post by twistedneck » Wed Dec 18, 2019 2:54 pm
I have a few usb midi keyboards and I'd like a module or a synth that can accept them directly without needing a powered USB midi box. those go from $70 to $200 and seem like money I could put towards the synth itself.
Many thanks!
Twistedneck
kpreid
Post by kpreid » Wed Dec 18, 2019 3:55 pm
There are several MIDI-CV interfaces which can act as USB hosts. Look for a USB "A" port on the face of the module. Here's a ModularGrid search (within Eurorack format) that turns up some of the modules with this capability.
I use the Expert Sleepers FH-2, myself.
ckwjr
Post by ckwjr » Wed Dec 18, 2019 5:53 pm
Polyend Poly has midi USB and USB hosting
mrhooks
Post by mrhooks » Wed Dec 18, 2019 8:29 pm
Not sure if this is what you're looking for, but String Theory is a Eurorack string synth module that accepts/requires a MIDI controller:
https://makesynthsnotwar.com/modules/stringtheory/
sduck
experimental use of gravity
Post by sduck » Wed Dec 18, 2019 11:33 pm
The squarp hermod will work with a arturia keystep with only one usb connection.
pulsewidth
Post by pulsewidth » Fri Dec 20, 2019 12:10 am
Monome Ansible has a MIDI mode, which has four different allocation modes: poly, mono, multi, and fixed. Haven’t tried it yet, but it sounds versatile.
twistedneck
Re: Do any modules or synths accept USB midi direclty (powered)?
Post by twistedneck » Thu Jan 23, 2020 4:16 pm
thanks for commenting everyone
new from namm
it seems there is a USB A port in the analog MFB synth pro
this is from the manual
'This device has exclusively been designed to generate and process audio signals as well as control signals corresponding to MIDI-, M-Bus- and USB-specifications. Any further use is not allowed and will preclude any warranty claims against MFB.'
i wonder if 'USB specifications' means - yea it'll power up a usb midi keyboard no problem and get all the note and cc data handled lol
time do do more searching on the recommended below
twistedneck
Re:
Post by twistedneck » Thu Jan 23, 2020 4:22 pm
wow that looks like a well built setup too something about it looks cool the video is still going nice
twistedneck
Re:
Post by twistedneck » Thu Jan 23, 2020 4:28 pm
wow why did i not see this i already ordered up an ES-9 but this might be even more powerful
i need to investigate
twistedneck
Re:
Post by twistedneck » Thu Jan 23, 2020 4:31 pm
this is super simple all i would need is a way to convert from your typical usb powered midi keyboard (primarily designed for pc connections) to the std 3.5 midi in
twistedneck
Re:
Post by twistedneck » Thu Jan 23, 2020 4:37 pm
very good thanks for helping kpreid
you now helped me clarify my thoughts im looking for a mini or used mega synth that i can leave in a Chicago practice area at a friends house something that will hook up directly to and power on of the many Native instruments / Arturia / Novation / Akai usb A power required keyboards
twistedneck
Re:
Post by twistedneck » Thu Jan 23, 2020 4:38 pm
hell yes it does good find
why do i feel like i 'need' all of these?
naxuu
Post by naxuu » Thu Jan 23, 2020 4:58 pm
If you already have some sort of MIDI to CV solution, Endorphin.es' Shuttle Mate is a USB MIDI host that will convert to DIN MIDI. Rackable, can be had used for around $100.
