Modular to Oscilloscope Cable
Voltage_Controller
Post by Voltage_Controller » Sun Jan 26, 2020 8:51 pm
What do you all use? I found this:
http://www.addacsystem.com/en/products/ ... /addac0017
But no other options. Is this the best/only thing on the market? Did you DIY?
I inherited a rather nice tube/vintage Tektronix scope and I want to see some sweet wave forms. Show and tell on how you connect your external scopes to your system. Thanks!
“The only truth is music.” ― Kerouac
sduck
experimental use of gravity
Re: Modular to Oscilloscope Cable
Post by sduck » Sun Jan 26, 2020 9:26 pm
I just clip the leads from a probe onto a patch cable. Not a problem for euro cables. For 1/4" 5U cables, I sometimes unscrew the endcap of the jack so I can clip on the leads.
ranix
Post by ranix » Sun Jan 26, 2020 9:58 pm
use an 1/8" or 1/4" to BNC adapter on a BNC cable
Teusa Rass
Post by Teusa Rass » Mon Jan 27, 2020 2:15 am
Cut a stackcable (a longer one) in two halves
and solder probe plugs to the ends.
msboude
Post by msboude » Mon Jan 27, 2020 12:34 pm
dooj88
Post by dooj88 » Mon Jan 27, 2020 1:16 pm
alligator clips attached from the scope probe to a long patch cable
bitSmasher
Post by bitSmasher » Mon Jan 27, 2020 7:37 pm
3.5mm mono to RCA cable, then RCA to BNC adapter taped on to it.
I use 'scopes a bit, exploring vector graphics, and don't see much value in hogging HP for connector conversions
Kattefjaes
Post by Kattefjaes » Tue Jan 28, 2020 7:01 am
I have a very ghetto little DS212 for basic troubleshooting, which uses passive 1x probes by default. I ordered some spares, chopped the ends off them, tinned with with a soldering iron. I had some handy mono 3.5mm sockets with screw terminals to hand, so being lazy, just screwed those on the end.
It works a treat- ran through calibration, things looked sane. Plugged some patch cables in from a running synth, and could see what was going on. Pretty sure that for audio rate stuff, adaptors or casual butchery will work fine for most 1x probes if you don't want to order those very tidy-looking cables.
acidbob
Post by acidbob » Tue Jan 28, 2020 7:47 am
I made my own with BNC and monojack in the other end, shielded.
Works ok, but sadly I dont have parts list, but they are available on ebay etc.
colb
Post by colb » Tue Jan 28, 2020 12:22 pm
I have a little pocket scope - seeed DCO quad. It works ok and takes up no room. The connectors are little MCX things, and I couldn't find a source for just buying plugs without extra hardware for crimping etc.
By far the cheapest solution was to buy this for £6
Chopping the lead off at the base, binning the antenna and adding a mono 3.5mm. Works a charm for Eurorack.
Just crazy that this was the cheapest solution.
Voltage_Controller
Post by Voltage_Controller » Sun Feb 02, 2020 11:13 am
Good tips / direction here. Thanks folks. :guinness:
Voltage_Controller
Post by Voltage_Controller » Sun Feb 02, 2020 11:15 am
Do you have a link? I am not seeing these anywhere.
ranix
Post by ranix » Sun Feb 02, 2020 5:59 pm
