What (non-standard) features would you like in a Buffered Multiple?
deftinwulf
Post by deftinwulf » Tue Jan 28, 2020 10:32 am
Hi everyone,
This is an "open poll" of sorts. I got to thinking about good old-fashioned multiples. A classic and necessary utility for modular synthesis.
Buffered multiples were the natural progression from the passive multiple. Attenu-inverting multiples, things like Lowgain Electronics' CVP-1 which has two 1->3 mult channels each with bipolar attenuation/attenu-inversion, could be seen as an evolution of the basic Mult design which has only in/out jacks.
What's the next evolution of this utility, do you think? Are there any "non-standard"/novel features you've thought you'd like to have in a Multiple that are missing currently? What features or changes would make a standard buffered multiple more than the sum of its parts?
Just a bit of a thought experiment I'd appreciate Muff's input on... All ideas welcome. :cloud:
dooj88
Re: What (non-standard) features would you like in a Buffered Multiple?
Post by dooj88 » Tue Jan 28, 2020 11:16 am
i use buffmults almost exclusively for pitch cv, so an evolution i'd like to see would be something a bit more interactive/performative.
it would be nice to have routing options for mixing.. so 2 separate cv inputs with an or/mix switch would be fun. we're moving away from mults at this point, but having precision adder functionality with the ability to route a +1v and an offset would be fun to play with.
deftinwulf
Post by deftinwulf » Tue Jan 28, 2020 5:47 pm
Ah, yes - good point - Buffered Mults are mainly necessary for pitch CV due to its sensitivity to voltage drop. So I really like your idea - a mult that can Or/mix from separate inputs and then mult from there. Maybe some kind of fun push-buttony interface to make it playable?
The CVP-1 I mentioned can act as 5V offset from its outs... To piggyback on your +1v precision adder idea, what if those pots on the CVP-1 were stepped/detented rather than smooth, with precise +1V per step/detent? If each side went to -4V / +4v, that would give you a 9-octave selectable range per mult output. The module might look something like a mashup between the CVP-1 and a ALM Beast's Chalkboard, but with 2 cv inputs per mult channel, and switches or pushbuttons as per your idea above...
Now, let's make it quad, just because we can. :mrgreen: 4 input channels, each with 2x CV inputs. :sb:
What do you think?
hamildad
Post by hamildad » Tue Jan 28, 2020 6:10 pm
I use the Club of the Knobs buffered multiple that also has 2x Attenuators (VCAs)
COTK C995CV
So I can mult pitch CV and have either 2x attenuators, or 2x VCAs for other fun stuff.
its a nice module when I wouldnt really want a single panel just for buffered mults, but think that 2x buffered mults is overkill. as mostly I mult out triggers rather than CV.
I also used to use the STG .BAM which had a single attenuator which was wired to a buffered mult so both could be independent or used as an attenuation > mult combo.
My Synth Instagram here * My Synth videos here
External PSUs and DC jacks are the hallmarks of toys. - Graham Hinton.
I am one of the "tiny fraction of a percentage of oversensitive idiots" who feels the name of this site sends the wrong message.
This is primarily for melody and historical educational purposes - Analogue Music
Thorsday
Post by Thorsday » Wed Jan 29, 2020 12:10 am
A larger buffered version of Doepfer A-182-1 in Synthesizers.Com format would be awesome.
dooj88
Post by dooj88 » Wed Jan 29, 2020 12:43 pm
i think that would be a sweet idea. with some normalling of the voltages to the other inputs, one could have a whole playable symphony going of related but variable pitches going!
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Wed Jan 29, 2020 12:50 pm
A combo of a buffered must and the opposite - a unity summer, would be nice. Work out a normalization scheme that would allow creative uses. Being able to combine a sequencer and a keyboard (for transposing) and then have it sent to multiple destinations would always com in handy.
-James
James
Post by James » Wed Jan 29, 2020 1:02 pm
This is EXACTLY what I've looked for on and off for a long time. I never need two pairs of buffered mults, so to be able to just send the oscillators right back, in a 2hp package, would be perfect.
thermisonic
Post by thermisonic » Thu Jan 30, 2020 10:10 am
a precision adder would make sense if k=no one has done that before
Navs
Post by Navs » Thu Jan 30, 2020 1:29 pm
When does a buffered mult cease to be a buffered mult? :hihi:
I've got a couple of Analogue Solutions' MX224s in my system, have done since I started. It seemed like a great, useful design:
Picture credit: https://www.schneidersladen.de/de/analo ... ?archive=1
Post by MindMachine » Sat Feb 01, 2020 11:45 pm
I have two of those. I also have a Plan B Model 9 Mixer/Attenuator set, which has the ver7 useful switches. I use EMW and Studio Electronics Boomstar Switches/Routers for all of my patches. I would include on/off switches on all mults but they will add 2hp.
FS: A-140-2 Dual VC ADSR, Erica VCA 2, SP-555 Sampler and more - CHEAP!!!
viewtopic.php?f=74&t=227738
thetwlo
Post by thetwlo » Sun Feb 02, 2020 12:02 am
free market research?
to rip off another's design?
why would you stoop so low?
Post by MindMachine » Sun Feb 02, 2020 4:20 am
That might be a little bit of the old jump to conclusions action, but if not, there are all kinds of designers and dealers that regularly post here for a tickle.
I like in/out switches on modules.
moremagic
Post by moremagic » Mon Feb 03, 2020 2:40 am
exactly, if youre gonna use an op amp to buffer it, use that inverted output for something
beepnsleep
Post by beepnsleep » Tue Feb 04, 2020 4:18 pm
Have you seen Frap Tools 333? 3x 3 input unity sums with 3 outputs each. each section normalised to the next so Use 1 input and it can be a 1:3, 1:6 or 1:9 mult, 1:3 +1:6, 3x 1:3 etc
https://www.modulargrid.net/e/frap-tools-333
Teusa Rass
Post by Teusa Rass » Tue Feb 04, 2020 8:09 pm
In my system I have an A-180 Doepfer, a Horstronic, and two of Fonik's attenuverters.
What I'd like to have is push button switches for the outs,
and/or pots that precisely snap in at Zero.
helix
Post by helix » Mon Feb 10, 2020 12:22 pm
LED lights on inputs just so they look nice. Bi colour for +-ve :yay:
JeebsFat
Post by JeebsFat » Sat Feb 15, 2020 8:03 am
Diatonic offset for pitch?
Divider for clock?
I like the idea of having a 1>3 mult paired with a 3>1 unity sum. I have a dual 1>3 next to a dual 3>1, but it's more than my small system needs.
I like the idea of a mult offset/mult attenuator.
wiperactive
Post by wiperactive » Sat Feb 15, 2020 9:44 am
Oh! 'Snap' - two here as well!
Opportunistically bought another second-hand and very cheap MX224 a few months ago while all my rig was in storage (and currently still is) before I became aware that not all buffers are created equal in terms of accuracy. With that in mind I added an adjustable AJH Synth V-Scale for more critical scenarios for when I get properly set up again.
Since I'm currently 'grounded', does anyone have any observations/measurements as to the accuracy or limitations of the ASol MX224?
Parnelli
Post by Parnelli » Sat Feb 15, 2020 5:24 pm
A buff mult with the ability to add a set value for pitch change and such when you're using one for pitch CV might be cool.
Blairio
Post by Blairio » Sat Feb 15, 2020 10:00 pm
My 4ms buffered mult has these and they are really useful for diagnostics:
The presence / absence of a signal
Its intensity
Its polarity
Its frequency
The 4ms also has video grade op-amps, so is a quality piece of kit. It is however 3HP, but that's what 1HP blank panels are for.
helix
Post by helix » Mon Feb 17, 2020 9:45 am
Its intensity
Its polarity
Its frequency
Exactly, i'm actually building myself a mult with these. 8 ins down the left, with each channel having two outs. A bi colour LED in between the in and out shows whats going on. This is all designed to be sending signals from my DAW, so nothing precise like 1v/oct
