Polyphonic MIDI->CV converters (for MU)?
Sir Ruff
Post by Sir Ruff » Mon Mar 02, 2020 12:29 pm
I'm looking to control up to 4 voices. I know about the encore expressionist, but what else should I be looking at? Needs to be either MU format or rack mountable. Bonus points if it has 1/4" jacks.
Fabong
Re: Polyphonic MIDI->CV converters?
Post by Fabong » Mon Mar 02, 2020 12:36 pm
Doepfer makes a 4-voice model, and I think Yarns can do it as well (possibly with caveats re: velocity I can't recall).
ALM makes the mmMIDI which can do 2 voices. Maybe you could get 2 of those?
Avant Garde a clue
bradovic
Post by bradovic » Mon Mar 02, 2020 12:39 pm
Here's some from cheap to more expensive :
CV OCD
Befaco MIDI Thing
Doepfer A-190-5
Mutable Instruments Yarns
Polyend Poly 2
Endorphin.es Shuttle Control
Sir Ruff
Post by Sir Ruff » Mon Mar 02, 2020 12:56 pm
I guess I should have been more clear--it will be powering MU modules so it needs to either be an MU module or something rack mountable. Euro modules are the only thing that won't work.
Randy
Re: Polyphonic MIDI->CV converters (for MU)?
Post by Randy » Mon Mar 02, 2020 3:18 pm
CV OCD, as suggested above, might work. It's not a Eurorack module.
http://www.tindie.com/products/hotchk15 ... to-cv-box/
Randy
kcd06
Post by kcd06 » Mon Mar 02, 2020 4:56 pm
moon m552 voltage to midi interface. never used one, but theres a good chance JLR has, might try him for more information, but its probably less than what you want.. I have a .COM quantizer with assistant, but its pretty limited, is mono, but does work fairly well.
Grove Audio have a polyphonic 5U midi to cv unit, not a clue if that could be reversed.
The most powerful, dangerous, wonderful word in any language occurs when an engineer-type person says "Huh..."
Sir Ruff
Post by Sir Ruff » Mon Mar 02, 2020 9:27 pm
thanks--you are totally right. It looks really nice actually, but I've decided I probably need a second CV output for velocity
looks perfect (i was looking for midi to CV, not other way around) except for above requirement regarding velocity. I am actually eyeing a Frostwave Quad midi->CV unit now. that looks like it probably foots the bill, though it would have been nice to have the converter as a module.
Gizmo
Post by Gizmo » Thu Mar 12, 2020 4:43 pm
CV.OCD with custom MU panel. Works for me. You'd need a second unit for 4-channel velocity.
https://www.muffwiggler.com/forum/viewt ... 2#p3129892
