Mutable Instruments CVPal
Moderators: lisa, Kent, Joe.
ac
Post by ac » Fri Aug 28, 2015 2:42 pm
I wonder if anyone has ever worked out any interesting "Modz" for that lower left corner...
waveplant
Post by waveplant » Wed Dec 16, 2015 7:29 pm
I've having calibration issues with my CVPal.
I'll calibrate and it'll work fine, then after a couple days there's voltage drop across the keyboard and I end up having to tune everything up - a few cents on the lower end of the range and about 30 cents at the upper end.
Is my calibration getting lost? Or could there be something interfering with it?
wejhead
Post by wejhead » Fri May 20, 2016 8:43 am
does anyone know if anyone is still selling the plexiglass cases for these things?
Booker, Oberlin Modern Music Guild
cargocollective.com/wmjohnson
http://holypagerecords.bandcamp.com/album/crawl-2
"Take it easy, but take it"
shred
desperation tentacle
Post by shred » Thu Jun 30, 2016 8:29 am
picked up a used CVpal the other day and hooked it up last night. I don't work with MIDI ever so it took me the better part of an hour to get Patterning app set with the proper MIDI channels. I primarily want to use it in channel 10 or 11 mode to send drum gates/triggers but I had some trouble setting the appropriate note values and therefore couldn't get anything to output. I did manage to get it set up in channel 1 mode so I could use 2 gates which was a ton of fun... just want to figure out how to get all 4 going.
Can anyone verify which specific notes are needed for modes 10 & 11? From the manual:
OUT 1: BD (note 36) trigger
OUT 2: SD (note 38) trigger
GATE 1: SD2 (note 40) trigger
GATE 2: CHH (note 46) trigger
Had to look up what the "GM drum map" was but it looks like note 36 is C1, 38 is D1, 40 is E1, and 46 is A#1 ... which I tried and did not work. But then I notice farther down the manual it mentions C3 being MIDI note 48 whereas on the GM drum map C3 is MIDI note 60 :hmm:
Does anyone have the correct note values for 36, 38, 40, and 46? It would be so much easier if I could input the numbers into Patterning but it goes by the scale values.
Thanks for your help
edit: this is the gm drum map I'm referencing
A Dingleberry Monstrosity wrote:CATS OR GTFO!!!!!
www.shredderghost.bandcamp.com
burdij
Post by burdij » Thu Jun 30, 2016 10:06 pm
The General MIDI standard specifies A4 = 440Hz as note 69. That would make C4 note 60. Some manufacturers specify C3 as note 60 but that would leave a lot of unused MIDI notes at the bottom of the range, probably not what the committee intended.
Knobcon 7 - 2018 Photo Album
While website and store updates are in progress, access the Grove Audio Synth Store
Tesla Science Center http://www.teslasciencecenter.org
shred
Post by shred » Tue Jul 05, 2016 8:19 am
burdij wrote:The General MIDI standard specifies A4 = 440Hz as note 69. That would make C4 note 60. Some manufacturers specify C3 as note 60 but that would leave a lot of unused MIDI notes at the bottom of the range, probably not what the committee intended.
thanks! i'll keep playing with it a bit more to see if I can lock it down
rayultine
Post by rayultine » Sat Jul 09, 2016 10:53 pm
Has anyone tested this thing with Windows 10 to see if latency is improved?
cheapmachines
Post by cheapmachines » Thu Jul 28, 2016 1:22 pm
pichenettes wrote: Image
Are these acrylic boxes still available anywhere?
adam
Post by adam » Thu Jul 28, 2016 5:15 pm
i'd been thinking about making some boxes/cases that fit - won't be exactly the same as that, anyone else interested?
i have 10 colours of acrylic piled up so can offer a choice of colours
Redukt
Post by Redukt » Sat Jul 30, 2016 10:36 am
rayultine wrote:Has anyone tested this thing with Windows 10 to see if latency is improved?
I can only say i'm more than happy with Win10 and CVpal. Never did any measurements and don't intend to so in the future as i generally don't care about these things as long as they don't get in the way...but it FEELS pretty responsive to me.
Never used it with Win7/8, so i can't comment on that.
adam
Post by adam » Sat Jul 30, 2016 12:06 pm
made these 3 cases on friday, each has a base the same colour, the cream and transparent ones have the protective film on still, the engraving is very crisp underneath, similar to the red one.
once you've cleaned the dust off you can infill the graphics with acrylic paint or a sharpie like falafalbiels does - then clean off the excess with alcohol, looks very slick.
i wanted to address the chronic lack of golf cart imagery on synth equipment finally.
REVIVER
Post by REVIVER » Tue Aug 02, 2016 7:37 am
Those look great, adam.
I'd definitely be interested in one!
adam
Post by adam » Tue Aug 02, 2016 11:27 am
thanks - just costed these and i can sell them as they are (no standoffs etc) for £7 + shipping
cheapmachines
Post by cheapmachines » Thu Aug 04, 2016 2:32 am
Couple of acrylic panels kindly cut by neilbaldwin :tu:
REVIVER
Post by REVIVER » Thu Aug 04, 2016 10:18 am
cheapmachines wrote:Image
Nice. What size are those standoffs?
cheapmachines
Post by cheapmachines » Thu Aug 04, 2016 11:23 am
They're this type:
Hexagonal brass stand off spacers, 10mm long with M3 3mm Male & Female threads. The hex bit is 10mm, screwthread adds about the same again.
There are black nylon M3 washers top and bottom and those give you about 1mm clearance between the top of the USB socket and the top acrylic panel.
It's a tight fit without the washers, probably easier to get some slightly longer stand offs. I was just using what I had laying around :hihi:
BTS
Post by BTS » Thu Aug 04, 2016 1:41 pm
I don't know if anyone noticed, but Synthrotek is selling the Sound Study Modular Midi 2 CV (kits, PCB and assembled), which is a off-shoot of the CVPal.
Check it out!
My site with links to my work: Box of Tapes Sound Recordings
Twitter @BTS0
Virgil
Post by Virgil » Thu Sep 15, 2016 1:14 pm
pichenettes wrote:
1. is it possible to run several units on one macbook ?.......on a USB hub ?
Very good question. I'll check tomorrow. Worst thing that could happen is that I'll have to set up a procedure to make sure each unit is flashed with different USB identification strings. You'll have a CVAmigo, a CVPote and a CVMitra.
Has this ever been answered or has someone tried multiple CVpals simultaneously?
mskala
Post by mskala » Mon Sep 19, 2016 1:33 am
I use two CVpals on a Linux-based single-board computer through a hub. No problems there.
Koa
Post by Koa » Tue Dec 06, 2016 12:08 am
any other windows 10 users reporting success with CVpal?
Local for sale and I am thinking about buying it.
shred
Post by shred » Wed Mar 22, 2017 2:39 pm
:zombie:
is it possible to add modes to the CVPal?
I would love a mode where all 4 jacks are independent pitch cv outputs.
Also would love one that's 4 lfo's. I know they'd only be 0-4v unipolar but that can be easily remedied with offset/attenuation/rectification.
mskala
Post by mskala » Wed Mar 22, 2017 2:58 pm
The DAC has only two analog outputs, which drive the first two jacks. The other two jacks are driven by digital outputs from the microcontroller. So a modified firmware could use the third and fourth jacks for triggers or gates, or I guess square wave LFOs, but they can't be pitch CVs or smooth-waveform LFOs.
shred
Post by shred » Wed Mar 22, 2017 3:04 pm
mskala wrote:The DAC has only two analog outputs, which drive the first two jacks. The other two jacks are driven by digital outputs from the microcontroller. So a modified firmware could use the third and fourth jacks for triggers or gates, or I guess square wave LFOs, but they can't be pitch CVs or smooth-waveform LFOs.
ahh, I see. thanks mskala
drip.feed
Roll it off at 30 Hz
Post by drip.feed » Sun Jun 11, 2017 10:01 am
Long shot: I'm looking for a CVPal panel. I have the pcb, but need a panel to stick it in my rack. UK/Europe preferably.
Dripfeed
homeless_peep
Post by homeless_peep » Wed Aug 02, 2017 11:06 am
I'd like to consider a CV pal for two voice operation, but I'm sceptical because of the whole latency thing. I'm on windows 7 ultimate.
I wonder, is there a way to mod this in order to receive midi data through the usual 3 pin midi interface? I can sure fit a 3.5mm stereo jack there. Would that improve latency at all? I can figure out ways to power it properly from my rack, but my skills at coding are quite basic.
