Argos Bleak - what do we know?
Digital Audio Electronics - discussion & support.
Moderators: Kent, solidox, governor blacksnake
rustyjaw
Post by rustyjaw » Mon Dec 18, 2017 5:45 pm
rustyjaw wrote:Anyone else have odd behavior when storing a preset (via holding down the encoder while pressing Chord)?
I've done this while a sequence is playing through the Argos Bleak and everything goes a bit wonky at the moment of saving - and after saving, some settings seem to be changed.
So after familiarizing myself more with the AB, I can answer my own question. What was confusing me is that when you save, the AB automatically returns to Chord preset 01. This is somewhat annoying, but not a serious problem.
Synth Enthusiast | Abandonment Photographer
mt3
Post by mt3 » Tue Dec 19, 2017 10:36 pm
Sorry for not following up. Free time luxury before the holydays.
Maybe it's a bug and send in a bug report?
mt3
Post by mt3 » Tue Dec 19, 2017 10:38 pm
Veqtor wrote:Argos delivers!
Your module boxes interior decorating looks identical to my environment.
:tu:
rustyjaw
Post by rustyjaw » Thu Dec 21, 2017 11:48 am
After my typical period of slow learning, I'm starting to get a handle on the Bleak. Here's a thing I recorded this morning. The bleak is controlling three oscilators here, a Dixie II, STO, and E330. There are two sequences going into the Bleak, both from the SH MkII. I use input swap to occasionally switch from one to the other. I built four chord presets on the Bleak which are being walked through by Rene. (the noisy fuzz that comes in after a while is the same sequence recorded into Morphagene, only I bumped up the octave dials on the AB before recording)
https://soundcloud.com/rustyjaw/beauty-in-the-bleak
guestt
Post by guestt » Thu Dec 21, 2017 2:02 pm
This is great :D
AB is making my modular sound a lot bigger than it is too - I think it has the record for being the most WTF? to the most OMG! module ever!
KoryB
Post by KoryB » Fri Dec 22, 2017 7:48 pm
rustyjaw wrote:After my typical period of slow learning, I'm starting to get a handle on the Bleak. Here's a thing I recorded this morning. The bleak is controlling three oscilators here, a Dixie II, STO, and E330. There are two sequences going into the Bleak, both from the SH MkII. I use input swap to occasionally switch from one to the other. I built four chord presets on the Bleak which are being walked through by Rene. (the noisy fuzz that comes in after a while is the same sequence recorded into Morphagene, only I bumped up the octave dials on the AB before recording)
this is fantastic!
yeatsvisitslincoln
Post by yeatsvisitslincoln » Sat Dec 23, 2017 9:17 pm
Question about the A+B and A-B outputs and how they are quantized. Is the math done to the two inputs before they are quantized? Or are they added together after quantization and then adjusted accordingly. I'm assuming it will never output a value that isn't in the scale mask (to steal a term from the O_C).
mt3
Post by mt3 » Wed Dec 27, 2017 5:27 pm
yeatsvisitslincoln wrote:Question about the A+B and A-B outputs and how they are quantized. Is the math done to the two inputs before they are quantized? Or are they added together after quantization and then adjusted accordingly. I'm assuming it will never output a value that isn't in the scale mask (to steal a term from the O_C).
Outputs are within the scale mask (sounds like it).
Unsure whether the A+B or A-B are pre or post quantizer.
what gives?
Post by what gives? » Sat Dec 30, 2017 3:46 pm
What's the range of the detune knob?
Villarceau
Post by Villarceau » Sun Dec 31, 2017 10:38 am
what gives? wrote:What's the range of the detune knob?
12 semitones.
6 semitones down and 6 semitones up
wireangel
Post by wireangel » Sun Dec 31, 2017 4:11 pm
https://soundcloud.com/rustyjaw/beauty-in-the-bleak[/quote]
Lovely tour through the fog, Rustyjaw! Haven't dug into those chord set ups yet. Still(happily) lost in the labyrinth of the SHii and Bleak paring. Inspired to dig further!
Happy New Year Harvestman folks!
dropthedyle
Post by dropthedyle » Sat Jan 13, 2018 8:01 am
The last firmware is real fun in arpeggio mode !
http://www.industrialmusicelectronics.com/news/13
mt3
Post by mt3 » Sat Jan 13, 2018 8:53 am
dropthedyle wrote:The last firmware is real fun in arpeggio mode !
Requires an announcement!
mt3
Post by mt3 » Sat Jan 13, 2018 9:07 am
from rustyjaw
"Final (promise :-) take on this patch. This started out as an exploration of the Argos Bleak, using most of it's features including all 4 outputs, both inputs, input swap, chord preset progression, vibrato and slew.
All voices are controlled by the Argos Bleak, the sequence is from the Stilton Hammer MkII. A second sequence is occasionally swapped for the main one to add a little variation.
The 4 voices are Dixie II, STO, E330, and Rings (being fed audio from Piston Honda MkII). All of the voices are fed into the 4 inputs on Three Sisters which I manipulate as things prDelay from 4MS DLD and Clouds in looping delay mode.
Everything is clocked from Pamela's Workout, which I manually slow down as the track progresses. Starting at 63 BPM and ending at 47."
mt3
Post by mt3 » Sat Jan 13, 2018 9:09 am
duplicate
rustyjaw
Post by rustyjaw » Sat Jan 13, 2018 5:16 pm
mt3 wrote:
from rustyjaw
Thanks! It's just a further variation on the "Beauty in the Bleak" soundcloud above. The main difference is using the 4th Argos Bleak output to drive a related melodic line, and filtering all the sounds differently.
Time to unpatch that and try something new now that I have a better handle on the Argos (and now with new firmware).
rustyjaw
Post by rustyjaw » Sun Jan 14, 2018 5:09 pm
Wow, I was just reading the manual again, trying to undertand the behavior of the CV in for "Destination" and something jumped out at me.
"in the RED mode, the CV will rotate the semitone data across the 4 outputs, with the attenuator acting as a manual control"
How did I miss this before? I know I read it, but somehow it never sank in, this is huge, IMO. Cycling the outputs? So nice!
Does the second part imply that (in RED mode) the CV in doesn't do anything...only the position of the knob?
mt3
Post by mt3 » Sun Jan 14, 2018 9:54 pm
rustyjaw wrote:Wow, I was just reading the manual again, trying to undertand the behavior of the CV in for "Destination" and something jumped out at me.
I believe it does? CV offset?
dysonant
Post by dysonant » Wed Jan 24, 2018 8:56 am
My world is about to get more Bleak. I'm picking up a AB later this week. I've got a question I'm hoping you folks can answer.
The Zorlon Cannon MKII CV output, even when at a constant level is somewhat noisy. I have run it through a quantizer before and I get undesirable trills because steps/gates are uneven. Has anyone used the Zorlon Cannon as a pitch CV source for the Argos Bleak?
mt3
Post by mt3 » Wed Jan 24, 2018 1:22 pm
dysonant wrote:My world is about to get more Bleak. I'm picking up a AB later this week. I've got a question I'm hoping you folks can answer.
I could test this out later tonight for you.
Unsure how Zorlon's Ch A Mix Out can be noisy, but I'll look into it. Do you mean each individual Out for Ch A, or Ch A's Mix Out?
dysonant
Post by dysonant » Wed Jan 24, 2018 3:10 pm
Definitely talking about the MIX out. I was looking at the MIX out on the DATA and messing around with the attenuverters. You can get different height steps/gates out of the MIX. Also, it is bi-polar, so I offset the MIX out to be above zero, then ran MIX into a quantizer. The result was a semi-random, but in key melody. However, the inherent noisiness of each gate (meaning the top of the square is not stable) made my quantizer freak out a bit.
mt3
Post by mt3 » Fri Jan 26, 2018 1:37 am
I'll have an O'Tool in next week so will report back then if I can't scope it by then.
Ch A is 0-5V and Ch B bipolar on the Zorlon. Nonetheless, the MIX OUT for both should be steady. I use it as a pseudo-sample-and-hold but never noticed the instability.
dysonant
Post by dysonant » Fri Jan 26, 2018 7:03 am
I was going out of MIX B. I am picking up my Argos Bleak tonight, so I will also see if I can scope and take some pictures of the ZC output this weekend.
dysonant
Post by dysonant » Sun Jan 28, 2018 10:28 pm
no idea why my last post was just a quote, I swear I posted something. Anyway, I have yet to test the Zorlon going into the Argos, but I will soon. Though here is my first patch with the Argos Bleak. Not quite so fancy, but I like being able to shift several VCOs at once
http://soundcloud.com/dysonant/exocomp-5
mt3
Post by mt3 » Mon Jan 29, 2018 1:38 am
dysonant wrote:no idea why my last post was just a quote, I swear I posted something. Anyway, I have yet to test the Zorlon going into the Argos, but I will soon. Though here is my first patch with the Argos Bleak. Not quite so fancy, but I like being able to shift several VCOs at once
Nice drop. What is the filtration(s) employed?
Return to “The Harvestman”
