Stillson Hammer MkII Mac Firmware Update with MPLAB IPE
Digital Audio Electronics - discussion & support.
Moderators: Kent, solidox, governor blacksnake
mt3
Post by mt3 » Tue Aug 02, 2016 11:42 pm
I'll update the pickit thread with this quirky info. Gracias for posting it!
@El_Miguel Excellent troubleshooting skills! :tu:
BlueWolfSe7en
Post by BlueWolfSe7en » Wed Aug 03, 2016 4:36 pm
Mercutio wrote:Hi
The leds are red on my Pickit 3
Power /active / status : all red with usb hub powered
Power/active : all 2 red with direct connect to imac ou with usb hub not powered
And MPLAB cannot connect...
My OS is 10.10.5.
During the installation of MP LAB, i receive an error message but installation finished...i can open MPlab and follow instruction but can't connect to pickit and "program".
Any idea ?
Same here
OSX 10 10 5
Power, active, status initially all red, then power & active remain red.
dsPIC33FJ128GP310
Apply
Checksum 19C
Tool shows as PICkit3 S.No : DEFAULT
Hit Connect get Connection Failed
Using MPLAB IPE v3.35
Any ideas anyone?
Strange Beautiful Machines
El_Miguel
Post by El_Miguel » Thu Aug 04, 2016 12:34 am
I would probably install Windows via Bootcamp or Virtual Box, install MPLAB for Windows and go from there. From what I read in forums the chance that it works is much higher.
Or as I did, go to your neighbors, check it with their computers or lent a USB Hub and try it again.
Good luck
Michael
A little bit more time for making music would be nice
https://www.modulargrid.net/e/racks/view/250402
mt3
Post by mt3 » Thu Aug 04, 2016 12:49 am
El_Miguel wrote:I would probably install Windows via Bootcamp or Virtual Box, install MPLAB for Windows and go from there. From what I read in forums the chance that it works is much higher.
Good luck
Michael
Even better than dual boot:
https://www.playonmac.com/en
BlueWolfSe7en
Post by BlueWolfSe7en » Thu Aug 04, 2016 4:10 am
Good luck
Michael
Thanks guys
Yeah I've tried every combo immanigable & no go.
Think it's probably specific to 10.10.5, that seams to pop up a lot on debugger forums! Seen one updated with a Mac & it was smooth sailing, was an older OS tho.
Edit...older OS was 10.9.5
Edit 2...5 mins with a PC, sorted. Windows version of MPLAB IPE automatically updates the picKIT too. Don't know why the Mac version doesn't do that?
Mercutio
Post by Mercutio » Fri Aug 05, 2016 3:28 am
:bang: with the latest OSX and my imac...i tried several hub powered or not...and all my usb port...
Mercutio
Post by Mercutio » Thu Aug 18, 2016 8:09 am
Finally worked with the pc of a friend... leds on the pickit was red during the process but firmware fully loaded...
On my mac i see that the pickit was recognize as a network... maybe it's the reason why it doesn't work !
mt3
Post by mt3 » Mon Aug 22, 2016 2:35 am
Mercutio wrote:Finally worked with the pc of a friend... leds on the pickit was red during the process but firmware fully loaded...
Once firmware was updated via PC, is it recognized as a network still under Mac?
echologist
Post by echologist » Sat Aug 27, 2016 12:52 pm
YES! successfully updated my stillson hammer mk2 :sb:
Thanks for this helpful tutorial!
Now onto my Piston Honda :tu:
pantalones
Post by pantalones » Tue Aug 30, 2016 3:32 pm
Are any of you located in the bay area/SF, CA, USA willing to let me come by and flash my firmware? $50 tax for a poor design decision from harvestman is kind of annoying. I'll bring a 6 pack.
mt3
Post by mt3 » Wed Aug 31, 2016 12:16 am
pantalones wrote:Are any of you located in the bay area/SF, CA, USA willing to let me come by and flash my firmware? $50 tax for a poor design decision from harvestman is kind of annoying. I'll bring a 6 pack.
Many have reported success with the $20 forties. :guinness: URLs should be included in 1st post.
auxren
Post by auxren » Wed Aug 31, 2016 1:40 pm
Sure! Message me and we can coordinate. I live in SF.
pantalones
Post by pantalones » Sat Sep 03, 2016 11:17 pm
Got this off ebay:
http://www.ebay.com/itm/331941067077
Arrived 2 days after I ordered it, firmware upgrade went smoothly, no problems whatsoever.
leoelectroid
Post by leoelectroid » Sat Mar 11, 2017 5:51 pm
Thanks for this, worked a treat
echologist
Post by echologist » Sun Apr 16, 2017 6:35 pm
sigh... after installing 1.666 with no issues, i now cant get past
"Target device not found" :bang:
Using the exact same set up :despair:
echologist
Post by echologist » Sun Apr 16, 2017 6:59 pm
sorted! :-)
mt3
Post by mt3 » Mon Apr 17, 2017 3:51 am
echologist wrote:sorted! :-)
Was the PicKit cable plugged in backwards?
echologist
Post by echologist » Mon Apr 17, 2017 5:05 am
Turned out to be a faulty usb cable...
metel909
Post by metel909 » Mon May 08, 2017 7:40 am
okay......holly shiiit i just did it with pickit2 on mac...
we have to download this app
Lucky that I found this blog ...thank goooddd
this guy might help us in a big time... -->François Gilbert
when you download .dmg file from François blog, read the read me and copy two files over into bin folder.
turn off the power and unscrew and take out the god brain :hail:
insert pickit2 into our master brain Stillson but make sure right way ... wrong position no good maybe...
however, when you insert pickit2 into Stillson then plug usb cable to your mac.
than open up the app
this is what I did
#1 click the "show connected PIC"
#2 choose the .hex file and click the stilson 1.8 .hex file
#3 click test hex--->click write hex---->click run hex
when run hex finished click test hex again after this job done Stillson went back to power off
than take out the pickit2 and put it back our master brain Stillson
screw it back and turn the power on
i saw number 1.800
:banana: :nana: :banana: :nana:
Good luck !!!!!
mt3
Post by mt3 » Mon May 08, 2017 12:46 pm
:tu:
Will update.
metel909
Post by metel909 » Mon May 08, 2017 1:05 pm
mt3 wrote::tu:
Will update.
I found this app developer on Instagram and I chat with him little bit lol
he said this .app was his little project when he was in school about 3 years ago.. :love:
and he asked me about what's Stillson Hammer and I explain to him briefly..
he sent me some photos of Pink Floyd tribute concert..two EMS synthi aks, vcs3..MINIMOOG and Memorymoog..he is fan of Pink Floyd :tu:
It could've been wasted all my sunday night for figuring it out how to use pickit2 on mac...
it was like :waah: :woah: :ripbanana: :cry: :doh: :deadbanana: and finally at the end soon as i saw the 1.800 :hail: :nana: :nana:
rhp3000
Post by rhp3000 » Wed May 10, 2017 5:09 pm
Niceee app, i have been using it for the updates (the one from the OP did not work for me)
Funny thing (from 2015): viewtopic.php?t=141282&highlight=
monads
Post by monads » Wed May 10, 2017 10:17 pm
Worked like a charm here! I just followed the instructions per the OP/website instructions. I'm on Mac OS Sierra (10.12.4).
Many thanks for taking the time to walk-thru :tu:
lonefront
Post by lonefront » Tue Nov 14, 2017 4:16 pm
Followed these instructions to successfully update from original firmware to 2.0 on a Windows 10 machine :party: Thanks for the clear instructions!!
guestt
Post by guestt » Wed Nov 22, 2017 5:55 pm
Just updated to 2.0 with High Sierra and MPEshitwhateverit'scalledlabthingy 4.05 - had to update the software and the firmware on the pickit before it would work!
liking the new firmware a lot - probability on things is good fun :D
Return to “The Harvestman”
