Piston Honda MKII
Digital Audio Electronics - discussion & support.
Moderators: Kent, solidox, governor blacksnake
reinklang
Post by reinklang » Mon Apr 10, 2017 2:41 pm
I just received a Piston Honda Expander which came filled with ROMs that have colored dots on them. I thought these might contain alternative wavetables but it seems they're just the standard set that was already included with the MkII. At least that's what it sounds like after loading the ROMs into the module.
Can anyone confirm this is correct? Or are they just empty?
friends don't let friends clap on 1 and 3.
mt3
Post by mt3 » Mon Apr 10, 2017 3:09 pm
reinklang wrote:I just received a Piston Honda Expander which came filled with ROMs that have colored dots on them. I thought these might contain alternative wavetables but it seems they're just the standard set that was already included with the MkII. At least that's what it sounds like after loading the ROMs into the module.
MARK II INSTRUCTIONS
from http://www.theharvestman.org/pistonexpander.php
- Turn off your instrument and remove the Piston Honda from the rack.
- Find the standoffs on the back of the module. Plug the expander board into the module, lining up the screw holes with the standoffs. It is not necessary to fasten the board with additional screws.
- Fill all six sockets on the expander with waveform ROMs, taking care to line up the notch on the socket with the notch on the chip.
- Hold down the "MODE" button in the Morph Discontinuity section.
- While holding the button, turn the instrument's power on.
- Wait one minute while the waveforms load from the expander to the memory. They will replace ROM (Z axis) locations A-F. When the load is complete, the module will activate and function as normal.
- Remove the expander board and re-install the unit in the rack. It is not necessary to leave the expander plugged into the MK2 piston.
JoshuaTSP
Post by JoshuaTSP » Wed May 17, 2017 7:56 pm
Artaos wrote:I can't figure out how to use the FM input on my Piston Honda mkII. Whatever signal I patch in the FM input (constant, AC, LFO, audio rate, etc), it has no effect on the sound. This is with the corresponding attenuverter full CW, full CCW, or anywhere in between.
The "CV" frequency input works as expected, it's only the "FM" input that doesn't seem to work.
Do I have a faulty unit or am I missing something?
Didn't see this get answered.
same question. Any answers out there?
mt3
Post by mt3 » Thu May 18, 2017 12:35 am
Works great here. Nice and gnarly knurls.
metel909
Post by metel909 » Thu May 18, 2017 6:34 pm
finally,,, I adopted them all...so happy to have them :love:
ianross
Post by ianross » Thu Aug 03, 2017 4:20 pm
Hey All,
Any update on the issue with the FM pot affecting pitch? Does have older firmware they could send me in the meantime?
I also mentioned in another thread that on my current PH mk2 2.5.1 I'm getting some noise/artifacts when I use the FM input and turn the attenuator clockwise. You can hear it with purer waveforms. Anyone else getting these artifacts?
guestt
Post by guestt » Sun Sep 10, 2017 7:22 pm
Mostly PH mk][ but also a really annoying exploration of timing shifts and fails, and the Hexinverter Snare too, drop just after 4:30:
https://soundcloud.com/kel/snare
snes
Post by snes » Tue Oct 03, 2017 4:42 am
Been trying to find the expander for my MkII. Does anyone have one they want to part with? Seems almost impossible to find any online.
Does the expander include any rom set's? or are they purchased separately? Sorry in advance if that has been asked previously.
mt3
Post by mt3 » Tue Oct 03, 2017 11:14 am
snes wrote:Been trying to find the expander for my MkII. Does anyone have one they want to part with? Seems almost impossible to find any online.
Took me a year to find one used.
ROMs and Expander boards sold separately.
snes
Post by snes » Tue Oct 03, 2017 9:21 pm
Thanks for the info.
Just to clarify, once the Roms are loaded onto the module, is there any need to hang onto the expander?
monstrinho
Post by monstrinho » Tue Oct 03, 2017 9:46 pm
Yes. There is no RAM that they would get loaded into, so you physically need both the expander and the chips themselves in order for the PH to access them.
snes
Post by snes » Tue Oct 03, 2017 10:25 pm
Thanks for the clarification! But i was under the impression the MkII expander overwrites the internal banks A-F as they are a duplicate from existing 0-5 banks?
mt3
Post by mt3 » Wed Oct 04, 2017 12:09 am
From the manual:
"The last 6 ROMs (A-F) may be overwritten by your own custom data, using the PISTON HONDA expander board. To use, plug the expander into the back of the module with the power OFF. Then, hold down the DISCONTINUITY MODE button and turn the power on, and wait one minute for the waves to load. Be sure to load all 6 slots of the expander, or you will have "blank spots" in the module's memory.
These waveforms are now written to the module’s memory, and you can remove the expander board."
PH mk I requires the expander board if I recall.
monstrinho
Post by monstrinho » Wed Oct 04, 2017 12:17 am
mt3 wrote:From the manual:
OK, so I'm wrong and there is onboard RAM?? I was always under the impression that the Piston Honda worked exactly like the Wiard Mini Wave / Waveform City, reading the waveforms directly from the EPROM chips.
mt3
Post by mt3 » Wed Oct 04, 2017 12:19 am
I'm unsure myself.
monstrinho
Post by monstrinho » Wed Oct 04, 2017 12:30 am
If The Mk 1 needs the Expander attached and the Mk 2 doesn't, that would seem to me to indicate that the Mk 1 reads directly from the EPROMs, but the Mk 2 loads the EPROM data into memory. At least that's how I understand the quote from the manual. Seems like the Mk 2 redesign was pretty extensive in that case...
snes
Post by snes » Wed Oct 04, 2017 12:57 am
Hopefully in that case, it might be easier to get a hold of a used board and roms for my PH MK II module. I might start scouring the marketplace for one...or if anyone reading this is interested in sending me theirs with ROMS? :love: of course i am willing to pay for it. :75:
guestt
Post by guestt » Tue Mar 13, 2018 12:02 pm
PHmk||| ??? pfffft!!! Picked up a second hand PHmk][ for a song and the two together are glorious!!!
Muwahahahahahah :hihi:
mt3
Post by mt3 » Wed Mar 14, 2018 3:14 am
Baddcr wrote:PHmk||| ??? pfffft!!! Picked up a second hand PHmk][ for a song and the two together are glorious!!!
:zen:
guestt
Post by guestt » Wed Mar 14, 2018 6:31 am
I don't know why I didn't think of it before, but having a pair of these is just awesome mt3
They are going really cheap, I mean I paid £199 for this one which just seems totally insane to me - you would barely cover the cost of the parts for that price! I would never have done this if it wasn't so cheap, but I am really glad I did, the possibilities are waaaaaaaay more than the sum of the parts if that makes sense.
xthrasherx
Post by xthrasherx » Wed Mar 14, 2018 6:59 am
I've been very tempted to pick up a Piston Honda mk II... I don't need another voice in my rack, but I've been wanting to try one out for a while. Maybe now's the time with the MKIII on the way.
"While we scream and perish, History licks a finger and turns the page.”
― Thomas Ligotti
Instagram::YouTube::SoundCloud
guestt
Post by guestt » Wed Mar 14, 2018 7:09 am
Do it... xthrasherx :tu:
Also excellent for LFO / modulation duties!
mt3
Post by mt3 » Thu Mar 15, 2018 1:21 am
Baddcr wrote:Do it... xthrasherx :tu:
Not just a VCO, not just an LFO, but can process external signals through its Wavefoldfukcshaper!
Try a cross-wavefolding patch with the the two PHmk][s.
:deadbanana: :omg: :goo: :sb: :twisted:
guestt
Post by guestt » Sat Apr 14, 2018 10:14 pm
This evenings jam :)
https://soundcloud.com/kel/doublehondare
Yeah, it's 2 Piston Honda :cloud:
... one wave folding the other, the delay from Time Sefari, manually tapped in heh! In fact, everything is unsynchronised, just played in real time - well, kinda - only Harvestman case used.
darylc
Post by darylc » Tue May 08, 2018 4:33 pm
Has anyone asked Scott about the FM input issue detuning main pitch?
If not, i'm going to ask him if it's possible to fix otherwise i'm reverting to FW 2.1
It makes pitched FM impossible as the tracking is knocked wayyy out with the CV/FM attenuverter
Really annoying as the full 0-5V CV input range makes it so much easier for xyz modulations.
Return to “The Harvestman”
