Polivoks Modulator
Digital Audio Electronics - discussion & support.
Moderators: Kent, solidox, governor blacksnake
mt3
Post by mt3 » Fri Apr 07, 2017 7:39 pm
Don't let me get your hopes up, I have no idea myself. It looks like your only option.
First guess would be to see if there's a resistor attached to either end of the LFO rate knob. Add a resistor in series, see what happens.
I'm pretty sure it won't be that easy.
Post by MindMachine » Sat Apr 08, 2017 7:52 pm
Might be worth asking the maker. I had the same request for a Bender to Pittsburgh and they offered to do it for free.
Infinity Curve
Post by Infinity Curve » Sun Apr 09, 2017 7:54 am
I might contact him. I know they are busy right now, and it's not really a priority. It's also already lost its place in the rack. I've put it aside for a possible expansion for the moment.
mt3
Post by mt3 » Thu Apr 13, 2017 9:52 am
Unsure if anyone else has noticed, but the first 25% (6 to 9 o'clock) of the LFO rate seems to not have any effect, rate is unvaried.
Can anyone confirm similar performance?
mt3
Post by mt3 » Fri Apr 14, 2017 2:30 am
Infinity Curve wrote:I might contact him. I know they are busy right now, and it's not really a priority. It's also already lost its place in the rack. I've put it aside for a possible expansion for the moment.
Might be of help:
http://www.doepfer.de/DIY/a100_capacitors.htm
mt3
Post by mt3 » Fri Apr 14, 2017 3:15 am
Infinity Curve
Post by Infinity Curve » Fri Apr 14, 2017 7:37 am
Ya I've noticed the curve on the frequency pot is kind of weird as well, Seems to slowly increase starting from slowest and turning up to around 1/2 and seems to speed up drastically last 1/4 turn to full speed. It's definitely not an even curve from slowest to fastest
mt3
Post by mt3 » Fri Apr 14, 2017 1:03 pm
Infinity Curve wrote:Ya I've noticed the curve on the frequency pot is kind of weird as well, Seems to slowly increase starting from slowest and turning up to around 1/2 and seems to speed up drastically last 1/4 turn to full speed. It's definitely not an even curve from slowest to fastest
Just read that might be intentional for the authenticity since the filter on the original Polivoks also shares similar characteristics regarding its resonance and cutoff!
issa4444
Post by issa4444 » Fri Apr 28, 2017 7:29 am
Thanks for the pdf mt3. :guinness:
Also having the same problem as Avjr. Mine just arrived today but the pcb literally seems to be sawed off at the bottom! Is this normal? just checking before I run the iron curtain with its bradder VCF and sestra Qotile.
Brate Guv'n'r :hail:
i s s a 4 4 4 4
mt3
Post by mt3 » Mon May 29, 2017 1:22 am
Here's the Polivoks Modulator as master clock as well as its S+H used in a patch.
The Moffenzeef stuff all sounds great.
EliphasOfCascadia
Humble Beginnings
Post by EliphasOfCascadia » Thu Feb 08, 2018 2:40 pm
super new to the modular world, wondering if I could have fun if all I had was a Harvestman Polivoks VCG and a MATHS to start? Looking to make a self modulating rhythmic ambient type system to play live drums to.
:help:
mt3
Re: Humble Beginnings
Post by mt3 » Thu Feb 08, 2018 5:09 pm
EliphasOfCascadia wrote:super new to the modular world, wondering if I could have fun if all I had was a Harvestman Polivoks VCG and a MATHS to start? Looking to make a self modulating rhythmic ambient type system to play live drums to.
:help:
If Maths has a VCA then yes.
Sinamsis
Post by Sinamsis » Sat Mar 24, 2018 10:41 am
Recently snagged one of these for my dedicated system. I agree that I'd like to see it go a little slower if possible. I don't really care about being true to the original. Has anyone figured out how to mod these? I may hit up Scott at some point, but I'd rather not bug him. I imagine he's busy cranking out some awesome new modules.
PietroC
Post by PietroC » Fri May 10, 2019 4:03 am
Flohr wrote:I use mine as my master clock. Feed one the square into the QCD. Very useful to have a master tempo knob, s/h, noise etc. in one small module. I rarely use the triangle LFO though.
Same Here as Master Clock Through Tempi ( Cool to have a initial Base Tempo)
Then can go as slow as i want Splitting the Channel on Tempi
Its Crazy as S/H Too Through Maths to have more control over limiting or augmenting pitch plus If you Run it Through the Kurzminogel after
Insane and some Malgorithm MK2 Madness to spice that up and why not wave shape through the King Slender while at it
:flamey:
catfisher
Post by catfisher » Thu Aug 22, 2019 7:30 pm
Came here to see if there was a trim pot I could access to make the lfo slower. Guess not. Thanks for the answers though, guys. The S&H is great.
jwm
Post by jwm » Wed Nov 20, 2019 4:35 pm
gah, just picked up one of these used and yeah, doesn't fit in my case either. that is super lame. :bang:
license
Re: Polivoks Modulator
Post by license » Sat Jun 13, 2020 12:55 am
Great, I found this thread after I ordered one, and my case is a Doepfer, so I'm probably in the same boat.
license
Post by license » Mon Jun 22, 2020 11:00 pm
Nope! I had to put it in the middle of the row, and the PCB had already (very obviously and roughly) been sanded down, but it juuust fit in there.
The pink noise (half-plugged S&H source) on this is great! I usually dislike snares that are pure noise, but this one does the job just fine.
There's also a slight slew on the S&H as well that I like - good contrast to the sharp edges of the Sampling Modulator.
Return to “The Harvestman”
