https://www.addacsystem.com/en/products ... s/addac403
https://www.addacsystem.com/contents/pr ... s_8612.pdf
Counting the days, right?
FTM...Arneb wrote: ↑Thu Dec 17, 2020 5:43 pmOk, this is probably a dumb question, but how do I get a normal 4ppqn clock for a 4/4 piece at 120bpm out of this thing? Do I work with time signature set to 4:4 or to 16:16? Can I use the Tuplets output to get a 3ppqn counterpart to the 4ppqn clock in this constellation? How do the Odds, Evens, Tuplets etc. outputs react when I use the x4 Multiply setting on tap tempo for this?
Right, but is the concept of "beats" in the Tempo section the same as in the time signature section? And if it is, how do I get a 4ppqn clock which is not awfully slow, given that a maximum of 250bpm would amount to 62.5 quarter notes per minute?soundslikejoe wrote: ↑Thu Dec 17, 2020 6:17 pmFTM...Arneb wrote: ↑Thu Dec 17, 2020 5:43 pmOk, this is probably a dumb question, but how do I get a normal 4ppqn clock for a 4/4 piece at 120bpm out of this thing? Do I work with time signature set to 4:4 or to 16:16? Can I use the Tuplets output to get a 3ppqn counterpart to the 4ppqn clock in this constellation? How do the Odds, Evens, Tuplets etc. outputs react when I use the x4 Multiply setting on tap tempo for this?
[BEATS P/BAR] sets how many Beats per BAR: 1 to 16
16 Beats P/Bar = 4 PPQN
Nah... you're thinking in "sequencer clocks" but this is thinking in Meter. BPM is not the same as time signature. Ex... If you have 120BPM and a Time Signature of 4|4, then you generate 120 quarter notes in 60 seconds. If your PPQN is 4ppqn in this scenario, you would have 4X120 pulses in 60 seconds.
The problem is that, as far as I can tell from the manual, those two bolded notions aren't distinct in the ADDAC403 - a time signature of 4/4 means Beats/Bar=4 and Beat Unit=4, and thus a 1ppqn Beats output. This is also reflected in the 5/4 time signature example on page 3.soundslikejoe wrote: ↑Thu Dec 17, 2020 9:04 pmNah... you're thinking in "sequencer clocks" but this is thinking in Meter. BPM is not the same as time signature. Ex... If you have 120BPM and a Time Signature of 4|4, then you generate 120 quarter notes in 60 seconds. If your PPQN is 4ppqn in this scenario, you would have 4X120 pulses in 60 seconds.
So... My assumption based on music theory and the layout of this module... If you set the BPM to 120 and the Time Signature to 4|4 and the BEATS/bar to 16... then you will have a super fast stream of 16th notes.
250BPM in 4|4 = 250 Quarter Notes per minute. At 4PPQN (aka 16 Beats/bar) you have 1000 clock triggers in 60 seconds.
I can see that pov... could be. If so, Digital Clocks would definitely suffer (Tempi and Pams) but QCD would work well. It doesn't suffer the same glitching in calculation of Mutl/Div that I've experienced with digital clocks. My plan was always to use this with QCD, and keeping the 403 to handle the barline resets for odd meter work. So....Arneb wrote: ↑Fri Dec 18, 2020 8:02 am
From a music theory vantage point, I'd guess that the idea is to use ADDAC403 with an external clock multiplier. However, clock multipliers don't work all that well in the real world. They glitch when the input tempo changes, which I'm afraid would take the fun out of ADDAC403's metric modulation CV inputs (pun intended).
I wonder how SCM holds up in that regard, since they're both from the same maker. (I don't own neither yet, just a Temps Utile which I'm seeking to replace.)soundslikejoe wrote: ↑Fri Dec 18, 2020 9:32 amI can see that pov... could be. If so, Digital Clocks would definitely suffer (Tempi and Pams) but QCD would work well. It doesn't suffer the same glitching in calculation of Mutl/Div that I've experienced with digital clocks. My plan was always to use this with QCD, and keeping the 403 to handle the barline resets for odd meter work. So....
From what it looks like to me in the manual, it's all a bit weirdly named. You have:The question I've had is does the unit treat 6/8 (or other compound meter) as having 6 beats, or two beats (as is traditional feel in classical music). Seems that the unit would program all Simple meters, and the use the Tuplet outputs to create Compound meters (6|8, 9|8, 12|8)
