Hi, I went through a lot a lof posts here and I also read the manual several times, but I do not seem to get the 207 working like I would and I have one problem that is not described anywhere. I am fairly new to modular synthesis so forgive my un-experience.
1.
When putting for instance an LFO CV signal into input one, the quantizer is (when only the C key is "on") going through a range of 4 or 5 C's. Is there a function to clamp the range of the incoming CV signal to a defined set of octaves, like just one octave? Or should the CV signal from the LFO (spitting out 0-5V) be processed to 0-1V *outside* the 207? If so, what module could do that?
2. The main problem: I can not get quantizer channels 2-4 play different notes set for channel 1. As a test I do this:
– I tuned two oscillators as described in the manual.
– A CV signal is going into channel input 1.
– I set channel 1 to play a C (in for instance a Major C scale)
And from here it goed wrong:
– I press button 2 for a second and select for instance an "E" for the second quantizer output and press it again to confirm, the 207 returns to quantizer mode. (I check again by pressing button 2 again for a second, and yes, the E key is lit up, where the C key is lit up for channel 1).
The manual states that the two outputs should play a C and E respectively now and that is what I want of course. But they do not: both oscillators still only produces Cs. The same happens when setting different notes for channels 3 and 4.
I can not get my head around this. Am I doing something wrong?
Any help would be highly appreciated! Thanks, Boele
ADDAC 207 help needed
1 post
• Page 1 of 1
Jump to
- Site Stuff
- ↳ Announcements - Please read!
- Modular Synths
- ↳ Eurorack Modules
- ↳ 5U Format Modules
- ↳ Buchla, EMS & Serge
- ↳ Fractional Rack Modules
- ↳ Modular Synth General Discussion
- ↳ Play Out! Performance Modulars
- ↳ Synthesis Techniques
- Other Music Gear
- ↳ General Gear
- ↳ Guitars, Basses, Amps & FX
- ↳ Music Software
- ↳ Music Tech DIY
- ↳ Video Synthesis
- Music
- ↳ Artist Discussion
- ↳ Production Techniques
- ↳ Synth Noise
- ↳ Your Tunes Here
- ↳ Synth Drone
- Official Company Forums - Proudly Hosted at Muff's!
- ↳ ADDAC System
- ↳ Aether Machine
- ↳ Alyseum
- ↳ Amazing Machines
- ↳ AMSynths
- ↳ AniModule
- ↳ Antumbra
- ↳ Audiospektri
- ↳ BugBrand Devices
- ↳ Ciat-Lonbarde
- ↳ Circuit Abbey
- ↳ DAEDSound
- ↳ Dwarfcraft Devices
- ↳ ELBY Designs
- ↳ Epinasty
- ↳ Expert Sleepers
- ↳ Extralife Instruments
- ↳ Flight of Harmony
- ↳ Folktek
- ↳ fonitronik
- ↳ Future Sound Systems
- ↳ Hexinverter Electronique
- ↳ I Dream Of Wires
- ↳ Keen Association
- ↳ KOMA Elektronik
- ↳ Konstant Lab
- ↳ Macro Machines
- ↳ Magpie Modular
- ↳ Mattson Mini Modular
- ↳ Metasonix
- ↳ Mobula Mobular
- ↳ Music From Outer Space
- ↳ nw2s
- ↳ Oakley Sound Systems
- ↳ PAratek
- ↳ RackPlanner
- ↳ Ross Lamond Designs
- ↳ SNAZZY FX
- ↳ soundmachines
- ↳ STG Soundlabs
- ↳ Studio.h Software
- ↳ Synthetic Sound Labs
- ↳ Tenori-On
- ↳ The Harvestman
- ↳ Totalmusik
- ↳ TouellSkouarn
- ↳ Trouby Modular
- ↳ Tubbutec
- ↳ Volta
- ↳ Wiard
- ↳ Zerosum Inertia
