Introducing ADDAC207 Intuitive Quantizer
Moderators: Kent, __ag
cptnal
Re: Re:
Post by cptnal » Tue Aug 25, 2020 4:21 am
deKaro wrote:
Tue Aug 18, 2020 9:38 pm
behndy wrote:
Mon Jul 15, 2019 3:11 pm
boop boop. got it in, and NIFTY. sitting down to learn my through the cute beasty and it's working different than i understood it would.
i have a melodic line CV going into 01 CV In, 01 CV Out to Rings, 02 CV Out to 2hp Sine. that works fineeeeee. since only the 01 CV In is plugged into, it dupes the quantized CV out to 02 CV Out as well.
but then i have different gate patterns going into 01 Gate In, 02 Gate In and 03 Gate In. and experiencing two things that are different than i expected.
01) i thought with a gate input that channel would only put out the note that was being quantized when that gate hit? like if the melody being put out was C D E F, and a gate was only hitting on when the C and E were going out the CV Out, you wouldn't hear the D and the F? maybe i have too long of a gate going in? but when the VCA for the Sine is open, i get the entire melodic pattern. like if i just trigger it every other beat, i hear the C then slide to the D the E then slide to F. was hoping to have the CV out freeze until the next gate.
02) it doesn't pass through to the Gate Out. on Channel 02 and 03 i was sending a different gate pattern to each, and the out to the envelope going into the VCA. if i stack cable the gate, then the VCA opens when it should, if i send out the Gate Out for that channel it..... some times does? i can't figure out WHEN it's triggering. i thought at first it was cascading like gates were read Channel 01 then 02 then 03 then 01 then 02 then 03 etc. but it's not doing that. just.... occasionally sends a gate.
what am i doing wrong?
Same here. On top of that, sometimes it works like expect and sometimes it doesn't. Sometimes it plays the individual notes and sometimes, when the rests are shorter, it plays the whole sequence of the Turing Machine I work with. :despair:
I will record a video today. I'm going directly from the Turing Machine into the 207 with normal cables (not stackcables).
I thought mine was bust for this reason when I first got it. After corresponding with Andre it seems the 207 needs a 10ms trigger. I get the feeling it may be a bit longer in real life, but haven't measured it. In any case a simple gate conditioner (I've used MI Stages) can work wonders, and can even bring a little "feel" to the rhythm.
What did confuse me though is that having a cable in CV inputs below the first isn't enough to break the normalling. There has to be a voltage present or the CV from inputs above still cascade down. Checking back, it does say that in the manual. :doh:
Is it finished?
Latest Tune:
Sounds: SoundCloud , Freesound
Racks: Big Case, Top Row, Funboat, Tinicase
deKaro
Re: Introducing ADDAC207 Intuitive Quantizer
Post by deKaro » Thu Aug 27, 2020 3:10 pm
Unfortunately that doesn't work with my 207. Is there a way to turn it on and off? Did I miss something?
i̫͚̬͎̻͗̉
R͋̇̒̏͂͋a̫̝̾ͬ̎ͫn̪̪̪͆̽ͧ͑d̾͑̒ͭͮͨͫo̖͉ͧͮmͦͬ̏ ͔͎̭̯̱͙̏͆̄̇ͪ͊w̠͖͈̖ͮ̌̑̑ͨ̌ͮẩ͙͎̩̺̳ͅĺ̰͖͙̒̌͆̇̎k̍̽͂s̹͎̫̆ͥͣͬ̉ ̣͍͕̬͉̲͑̓͗́͗o̿ͪ̑ͦ̏ͫn̒ ̮̘̜̘̪̉ͭn̮̲̼͎͓͎̮͊ͨ̇ͨͮȇ̮̦̻͖͈̇̓̉ͣv̲̬̪̟̟ͬe̿̔̽r̰̹̍̐̀-̬ͨ̿ë́̅̎̿ͯ̋͑n͍͈͎͙͖͋dͅi̫͚̬͎̻͗̉ñ͈̱g̞̯̠̈́̐ͨ̔̈ͩ ̙͙̹͙̠͍ͮ̀̉ͯ̾p̯͖̰̫͉͇͔a͇t̩̜̗͎ͫ͐ͯ̌͐̓ṭ̭͆̃ͩ̓ḛ̫͈͖̠̼͚̑̇̂͐r͓̳͚͗̅ͩ̋̽̀́ṉ̣͚͔̝͓̎̋̂ͅ
https://www.youtube.com/tonydekaro
Triglav
Post by Triglav » Thu Aug 27, 2020 3:51 pm
I've posted about this on the last page. This is either a bug or an undocumented feature. I've made it work again by long pressing button 7 then making sure button 2 is lit.
deKaro
Post by deKaro » Thu Aug 27, 2020 3:53 pm
Many thanks! I will try this! :tu:
i̫͚̬͎̻͗̉
deKaro
Post by deKaro » Thu Aug 27, 2020 4:02 pm
Yeah! It works! Thank you! :hail:
i̫͚̬͎̻͗̉
deKaro
Post by deKaro » Thu Sep 24, 2020 1:56 pm
Is there a version of the User Guide, which is "searchable" with Ctrl+F?
It's a little bit difficult by scrolling 30 pages when I want to look something up. :hmm:
i̫͚̬͎̻͗̉
cisco1984
Post by cisco1984 » Fri Oct 16, 2020 5:13 pm
I would very much like a new update! i have so many problems with this quantizer.
Del
Post by Del » Sun Dec 27, 2020 2:37 am
Just checking: Does this quantizer quantize chords within a key? For example, if only the IN of the first channel is patched and three outputs are patched to oscillators, if I feed it C, D, F, and I'm in the key of C MAJOR, will it give me a minor chord for D, and major chords for the other two? Thanks.
mr.pink
Post by mr.pink » Fri Jan 15, 2021 12:28 pm
I find this very non-intuitive and confusing too. Moreover it doesn't happen immediately. I have attenuators before the inputs, when I dial it to zero it goes on "normally" for a while, but after some time passes it starts to mirror input 1. Is it really that hard to implement sensing of input cables? Right now I'm using only channels 2, 3 and 4 and ignoring 1 because of this. I don't care about harmonization, I just want 4 equal quantizers.
Also I second the request for a searchable manual. For most of my modules I don't need a manual, the 207 is an exception, and a PITA to find what I'm looking for. And maybe you should consider hiring a technical writer (or better translator), it is not well written and full of the infamous translation "stink" (I'm also not a native speaker, but this is a bit too much).
Return to “ADDAC System”
