Ming Mecca and Micro Info and World Core Packs
Moderators: Kent, luketeaford, Joe., lisa, daverj
- SPIKE the Percussionist
- Veteran Wiggler
i am just posting this here since i had a very frustrating time trying to find these files.
only to realize that i had them all this time with the Ming Micro.
hope this helps someone out!
these files will work with both the Ming Mecca and Ming Micro devices. These are the sample world designs: --
and here is the info from the TXT files:
MING MICRO QUICK START GUIDE
Turning on the Device
Ming Micro does not have a power switch. Simply connect the AC Adapter to the power port.
Handling the Device
Ming Micro is fairly robust but, as an exposed PCB, some care must be taken not short components during operation. Do not touch the bottom of the PCB (even with your hands) during operation. If you do, it won’t hurt Ming Micro, but it can cause the main processor to crash, requiring physical reset (i.e., the Reset Button, instead of the Reset CC).
Hot-Swapping
Ming Micro is fully hot-swappable —all cables, jumpers, and even the SD card can be inserted or removed live without damaging the device or interfering with operation. Take care not to remove the SD card or power off Ming Micro during SD Read/Write operations, however (indicated by the READ and WRITE LEDs)
Selecting USB or DIN MIDI
Jumpers J4 and J3 toggle between USB MIDI and DIN MIDI. Their positions are marked on the board. both jumpers should always be moved together.
Using USB MIDI
Ming Micro is a fully class-compliant USB device, so no driver installation should be necessary. When you connect Ming Micro via USB, Audio MIDI Setup (or, on Windows, the device manager) should show a new midi interface labeled “Ming Micro.” Ming Micro will display both an input and an output. The output is not currently used.
Loading and Saving World Packs
To load a World Pack, simply insert an SD Card with a WPACK.TXT file and press the Reset button once. Ming Micro will reboot and load the new World Pack into memory
To save a World Pack, hold the save button for 3 seconds. A progress bar will appear on the LED graph display. Once completed, it’s safe to remove the SD Card.
Note that saving will override (replace) any WPACK.TXT file currently on the SD Card.
Loading and Saving can also be automated using MIDI CCs 46 and 47 (see midi implementation chart).
Updating Firmware
Unfortunately, there wasn’t enough room left in memory to include an SD boot loader.
Firmware can be updated in two ways:
1. Replacing the Firmware EEPROM
2. Programming the existing EEPROM using the PGM port
to program the existing EEPROM, you’ll need to purchase the Parallax Prop Plug, available here:
https://www.parallax.com/product/32201
Otherwise, i can send you new pre-programmed EEPROMs as needed (or, you can program the EEPROMs yourself directly, if you already have an external EEPROM programmer). the EEPROM is socketed for easy removal.
Ming Mecca / Micro Users Guide Note
Since Ming Micro and Ming Mecca share the same underlying architecture, we’ve included a copy of the Ming Mecca User’s Guide for reference. Chapters 1, 2, and the appendices can be safely ignored, but Ming Micro owners should find chapters 3, 4, and especially 5 to be illuminating. Chapters 3 and 4 deal with the graphics engine architecture, and include a number of helpful illustrations. Chapter 5 deals with World Pack creation (a .TXT asset format common to both systems), and contains a brief overview of WPACKer, our .PNG to .TXT conversion tool.
Although the Mecca and Micro engines are similar, they are not identical; a list of Ming Micro’s differences from Ming Mecca is provided below.
MING MICRO hardware:
Choose between the integrated USB/MIDI interface or standard MIDI DIN
Class Compliant USB support on all OS’s or optional proprietary low-latency driver for Windows
Audio and Video output on RCA jacks
9V DC power input
Save and Reset buttons
LED Graph Display visualizes MIDI/Engine activity and system states
SD Card Slot loads WPACK.TXT and CONFIG.TXT files, fully cross-compatible with MING MECCA
Expansion Port
Differences from Ming Mecca:
Increased sprite and tile count: 3 sprites, 4 tiles
Sprites can be positioned in coarse (cc) or hi-res (pitch bend) modes
Improved Tile Map Editing uses x / y positional system
Dynamically modify palettes by editing individual colors
Pixel Draw system allows Tile and Sprite graphics to be modified, erased, or created in realtime
Save function commits any changes to WPACK.TXT
All new glitch system allows RAM to be “scrolled” using hi-resolution pitch bend messages
Software emulation of Oscillographic Block’s SN76489AN audio chip
3 channels: square1, square2, noise
pitch and amplitude control of all channels
Includes hi-resolution mode using pitchbend messages to control chip’s full frequency range
MIDI keyboard (note / velocity / pitch bend) support, includes basic “note stack” for trills and ostinattos
Sprite Lock feature allows audio parameters to be internally driven by sprite position
no collision
no gravity
no relative sprite position
no gamepad support
no physical interface except for Save and Reset buttons
Handling the Device
Hot-Swapping
Using USB MIDI
Updating Firmware
9V DC power input
Expansion Port
no collision
no gravity
no gamepad support
more noiz!
- http://www.manipulate.net -
ASTROGENIC HALLUCINAUTING
CoRE - Constructs of Ritual Evolution
DOGGEBI
Fiddle Witch and the Demons of Doom
morgue city
Unified Space
more noiz!
DOGGEBI
morgue city
Unified Space
- FetidEye
- demonic space drone
Re: Ming Mecca and Micro Info and World Core Packs
cool.
I'll share this info on the Video DIY google drive:
https://drive.google.com/drive/u/2/fold ... DcgoGBOaEW
- spacenoodle
- Veteran Wiggler
Thanks for collecting this stuff. I have the DIY build instructions:
I also seem to have gone full geek and documented Ming Micro's USB:
Device descriptor:
Descriptor Length: 12
Descriptor type: 01
USB version: 0200
Device class: 00
Device Subclass: 00
Device Protocol: 00
Max.packet size: 10
Vendor ID: 0A4A
Product ID: E511
Revision ID: 0100
Mfg.string index: 01
Prod.string index: 02
Serial number index: 00
Number of conf.: 01
Configuration descriptor:
Total length: 0065
Num.intf: 02
Conf.value: 01
Conf.string: 00
Attr.: C0
Max.pwr: 00
Interface descriptor:
Intf.number: 00
Alt.: 00
Endpoints: 00
Intf. Class: 01
Intf. Subclass: 01
Intf. Protocol: 00
Intf.string: 00
Device descriptor:
Descriptor type: 01
USB version: 0200
Device class: 00
Device Subclass: 00
Device Protocol: 00
Max.packet size: 10
Vendor ID: 0A4A
Product ID: E511
Revision ID: 0100
Number of conf.: 01
Total length: 0065
Num.intf: 02
Conf.value: 01
Conf.string: 00
Attr.: C0
Max.pwr: 00
Intf.number: 00
Alt.: 00
Endpoints: 00
Intf. Class: 01
Intf. Subclass: 01
Intf. Protocol: 00
Intf.string: 00
Does the company Special Stage Systems even exist anymore? Their website seems to have disappeared.
Avant Garde a clue
He posts stuff on YouTube occasionally as Synk Sentury. It's not really related to anything video synthesis related though, more him theorizing about the nature of everything.
This might be the wrong place to post this but might anyone have a Ming Micro they would be open to selling?
Or what kind of process and cost would go into having a Ming Micro built?
- monads
^Not sure. Someone might have info. Have you considered just going the World/Control modules?
- Veteran Wiggler
more noiz!
DOGGEBI
morgue city
Unified Space
more noiz!
DOGGEBI
morgue city
Unified Space
