LZX Cadet Series (DIY/Assembled)
legs
Post by legs » Mon Jun 24, 2019 11:40 pm
WTB: A-166, WogglebugV2
Starspawn
Post by Starspawn » Mon Jun 24, 2019 11:55 pm
That all looks good. How are you testing it? The RCA s input and thru, and you do have to have an input for it to do things, but also if you then use it with an encoder you should connect the sync cables before expecting a proper output from the encoder. But with that given a cable from the sync outputs in front to a RGB input should give you a result other than black.
legs
Post by legs » Tue Jun 25, 2019 12:04 am
If I only hook up an encoder to my tv with composite and 1V going into red would I see something? I'm not hooking anything into the RCAs on the sync generator.
Return to “Video Synthesis”
