3TrinsRGB-1c Triple CV Comparators - kits available
Moderators: lisa, luketeaford, Kent, Joe., daverj
FetidEye
demonic space drone
Post by FetidEye » Sat Oct 29, 2016 3:28 am
PCB's + kit parts are in!!!
I'll PM everybody on the list with details :cloud:
maggan
Post by maggan » Tue Nov 01, 2016 6:58 am
I am interested in this. Put me on waiting list. :)
FetidEye
demonic space drone
Post by FetidEye » Tue Nov 01, 2016 10:49 am
you are on the list
the V3 buildguide in back online!!!
build updates:
all build eurorack modules are shipped!
:omg:
FetidEye
demonic space drone
Post by FetidEye » Wed Nov 09, 2016 3:37 am
I've updated the build guide for version 3
It now includes:
lasercut panel files (eurorack and standalone enclosure) - Illustrator format
schematic
FetidEye
demonic space drone
Post by FetidEye » Fri Nov 11, 2016 7:20 am
new pcb's are in!
jjplano
Post by jjplano » Mon Nov 14, 2016 2:21 pm
hi!
do you have a full kit with eurorack panel/enclosure to send right away? I'm going to travel soon.
thanks!
FetidEye
demonic space drone
Post by FetidEye » Mon Nov 14, 2016 3:01 pm
yes those are available again.
i'll pm you
theflyingfridge
Post by theflyingfridge » Tue Nov 15, 2016 12:53 am
FetidEye wrote:yes those are available again.
i'll pm you
I'm also interested in a built kit with full enclosure. PM'ing you now...
ehafh
Post by ehafh » Fri Dec 02, 2016 1:22 pm
hello,
i would like to buy - PCB + Eurorack panel (wood): 29,- euro
i'm located in the USA. please send me a PM whenever and i'll get it paid :]
ISOTROPOSPHERE
Post by ISOTROPOSPHERE » Sun Dec 18, 2016 11:25 am
Just finished my 3x cv comparator, now on to testing, labeling and decorating the housing. Just a helpful hint when building, the patchbay header should be adjusted for vertical height as well before final soldering. The pins are long so you have lots of play.
Technosaurus small wonders complete owner. 39U 19 inch rack width worth of euro rack. Electribes, Z1, Pro2, Casio sk-1,5,8 bent, VZ-1, VZ-8m, voices processors and vocoders, dozens of DIY devices and circuit bent creations.
On the tube channel same as username here.
FetidEye
demonic space drone
Post by FetidEye » Mon Dec 19, 2016 4:48 am
looking good!
maggan
Post by maggan » Mon Jan 02, 2017 4:41 am
Where do I find the 20k lin 9mm alpha vertical pot?
FetidEye
demonic space drone
Post by FetidEye » Mon Jan 02, 2017 5:28 am
You can find a 25k at Thonk
Tayda stocks 20k
maggan
Post by maggan » Tue Jan 03, 2017 4:09 pm
FetidEye wrote:You can find a 25k at Thonk
Tayda stocks 20k
Darn, I already ordered from thonk twice, didn't want to take a chance on the 5k diff. They are sending my stuff tomorrow, will try to ask them about adding these.
maltemark
Post by maltemark » Tue Jan 03, 2017 4:30 pm
Tayda stocks 20k
De' ärnte så thonk-businessen funkar grappen! En lagd order är en lagd order-princip
maggan
Post by maggan » Wed Jan 04, 2017 4:31 am
De lade ihop mina ordrar faktiskt. Dock han jag inte få med pottarna i den. :P
maltemark wrote:
Tayda stocks 20k
maltemark
Post by maltemark » Wed Jan 04, 2017 6:53 am
maggan wrote:De lade ihop mina ordrar faktiskt. Dock han jag inte få med pottarna i den. :P
maltemark wrote:
Tayda stocks 20k
Scandal! Unfair!
sync24
Post by sync24 » Wed Jan 04, 2017 7:30 am
I'm thankful to google-translate right now :tu:
maggan
Post by maggan » Wed Jan 04, 2017 8:52 am
sync24 wrote:I'm thankful to google-translate right now :tu:
Oh! The way we where writing I am suprised anything got thru. :D
FetidEye
demonic space drone
Post by FetidEye » Tue Jan 10, 2017 3:13 am
With a few people, the mail service was really slow.
But the packages did arrive , if not very overdue.
(with the exception of one, for now)
If any of you did not get the kit / pcb yet, please contact me
There is only one thing I want for people; to have fun with this module!
maggan
Post by maggan » Wed Mar 01, 2017 6:29 pm
Hi!
Can I use sn74hc14 instead of the cd74hc14?
The first one I have laying around for some reason the other one I need to order if the first one is no good! :)
Thank you for a nice build guide btw! :D
FetidEye
demonic space drone
Post by FetidEye » Wed Mar 01, 2017 6:37 pm
i'm not super fluent in these codes, but it looks like it might work.
(i checked the pdf sheets of both)
try it out, i should say :)
maggan
Post by maggan » Wed Mar 01, 2017 6:49 pm
I'll try!
maggan
Post by maggan » Fri Mar 10, 2017 5:05 am
I think it works.
sebiiksbcs
Post by sebiiksbcs » Sat May 06, 2017 12:04 am
Hi, so I finally got around to building this (V2) and it rocks! Thanks FetidEye.
In case anyone's interested here's pictures of the PCB and you can see some simple mods I did for my convenience and use case. The mods are:
- 100k pots for CV amount instead of voltage dividers R17,R18 / R19,R20 / R21,R22 (the third CV pot isn't installed yet) (this way the 3trins is unprotected I know, but I use the comparator with 3trins-internal signals and non-modular audio so voltages are pretty low)
- alternative 2.54mm header inputs for CV inputs (for 3trins convenience)
- switch for combining inputs (not sure if this is the same mod like someone further up in this thread did before, it is a simple on/off/on switch that sends input 1 > 2 or input 2 > 3 if required
Return to “Video Synthesis”
