LZX Industries Orion Memory Palace
Moderators: lisa, luketeaford, Kent, Joe., daverj
SPIKE the Percussionist
Post by SPIKE the Percussionist » Thu Nov 21, 2019 6:49 pm
Question...
i am considering acquiring a Memory Palace and i was wondering if anyone could tell me if there are any issues with installing it into a somewhat standard modular case.
i have an old 6U Enclave case that looks like it has more than the required 50mm worth of depth for the Memory Palace requirment.
but of course...i need to consider the space lost by an Intellijel PSU.
:despair:
any insight regarding any issues anyone has had installing one would be very helpful!
thanks!
more noiz!
- http://www.manipulate.net -
ASTROGENIC HALLUCINAUTING
CoRE - Constructs of Ritual Evolution
DOGGEBI
Fiddle Witch and the Demons of Doom
morgue city
Unified Space
lzxindustries
Re: LZX Industries Orion Memory Palace
Post by lzxindustries » Mon Mar 30, 2020 10:32 am
The deepest part of Memory Palace is only about 16hp wide and the rest of the module is only about 15mm. If you have a right angle RCA sync cable you shouldn't have any trouble fitting into your setup.
lzxindustries.net
monads
Post by monads » Mon Mar 30, 2020 5:36 pm
Also be aware of the fan noise from the Memory Palace if placing into a small case as it will sound that much louder!!! A bigger case with depth helps displace the fan noise.
Return to “Video Synthesis”
