Ming Mecca - Voltage Controlled Videogame Console
Moderators: lisa, luketeaford, Kent, Joe., daverj
shaurjyabanerjee
Post by shaurjyabanerjee » Fri Jun 03, 2016 10:15 am
The Ming Mecca has basically just obliterated my desire for any audio modules aside from the ones I have already :eek: :eek: :eek:
spacenoodle
Post by spacenoodle » Sun Nov 27, 2016 8:39 pm
monads wrote:
spacenoodle wrote:I've got it working with a Panasonic DMR-E85H DVD/hard disk recorder. The output is 480i component. Conveniently, it just passes the converted signal through when it's on. This will also work with a Philips DVDR-985, although they are considerably less reliable and more bulky than the Panasonic.
I went ahead and tried as spacenoodle, but with a lower version model; Panasonic DMR-E80H DVD/hard disk recorder :hihi: It has the same component spec. It works fine as reported. I did notice the pass through signal (when static) has a noticeable, almost instantenous refresh rate. It's super minor, and you will not be able to tell/notice this with Ming Mecca being animated/CVd. I just thought I should point this out.
The below worked perfectly with the Panasonic model:
-Component connection connected to the Visual Cortex, locked fine.
-RCA Video Out to the LZX TBC, and the TBC to Visual Cortex. No problems.
-RCA Video Out to MVIP. No problems.
So..although I would've liked to have a module to avoid a bulky recorder to accomplish the above it's no big deal. I can also save modular space for other video modules!!! I grabbed a working player w/remote for $120. You can likely save money by going with a broken unit (optical drive). If a expander module is ever released, I'll still purchase one just to have on hand :tu:
After a bit of testing I found a better solution. An Extron TSC-100 before the Ambery fixes the problem. You can even skip the Ambery (monochrome) - the TSC puts out clean 480i. I might have some other options shortly, still experimenting.
ehafh
Post by ehafh » Tue Jan 10, 2017 2:05 pm
any update on progress of the expansion module?
Matos
Modular masturbator
Post by Matos » Thu Feb 09, 2017 2:28 am
Reading the manual and it mention many more modules were planned. Is this still the case? Any other modules in the works to add to the special stage family?
Jaytee
Post by Jaytee » Fri Feb 10, 2017 10:00 am
Matos wrote:Reading the manual and it mention many more modules were planned. Is this still the case? Any other modules in the works to add to the special stage family?
I have no inside information, but Special Stage Systems released two products in the last year (Ming Micro and Oscillographic Block), so it's not as though they're sitting on their laurels.
Matos
Modular masturbator
Post by Matos » Fri Feb 10, 2017 12:17 pm
I wasn't implying that they were. The micro is excellent but in no way interfaces with the world core. While the oscillator could be thought as a sonic addition to the video system, I'm more curious if there was any planned additions to the video system or if development is complete.
monads
Post by monads » Fri Feb 10, 2017 10:42 pm
I love Jordan. Oscillographic Block (OB) is awesome and Ming Mecca is the shiit. Ming Micro was not the (crowd funded??) follow-up ming mecca users were looking or hoping for. And like 'Matos' said...curious on expansions/addition VIDEO modules to ming mecca.
monads
Post by monads » Thu Feb 16, 2017 11:20 pm
So now the website is down? Jordan????
ratsnake
Post by ratsnake » Fri Feb 17, 2017 7:01 am
:deadbanana:
in other news, my kit arrived and will pick it up at the customs office. finally!
DSC
Post by DSC » Sat Feb 18, 2017 6:51 pm
monads wrote:So now the website is down? Jordan????
Hope that is not the shape of things to come!
spacenoodle
Post by spacenoodle » Sat Feb 18, 2017 8:44 pm
Did he ever finish the Ming Micro editor or is that still in the works?
Matos
Modular masturbator
Post by Matos » Sun Feb 19, 2017 1:07 am
It should be on the sd card. The card has the manual, editor, and the sprite editor thing with a weird name.
yan6
Post by yan6 » Thu Feb 23, 2017 3:00 pm
Does anyone have a copy of the WC and CC firmware. I was looking for it but their website seems down :hmm:
ratsnake
Post by ratsnake » Sat Feb 25, 2017 9:13 am
ratsnake
Post by ratsnake » Sun Feb 26, 2017 2:55 pm
cskonopka wrote: Have you tried the 3Trins? This potentially could work, I did not have it at the time I started with the roo.
monads wrote:Didn't try the 3Trins, any mixers, or other bulky device (i.e. DVD disk recorder).
I haven't been able to get my 3trins to lock the input from the ming micro. might be a totally different beast. My old usb capture also has some sort of issue with the signal (some colors are vertically interlaced. Probably doesn't like 240p ntsc or something. A projector I have has 0 issues displaying the colors perfectly from the MMicro though. whew.
Muntic0re
Post by Muntic0re » Thu Apr 06, 2017 4:31 am
It's really a great idea. But it seems to be very expensive almost 1000$ :( Well I need to save money from now :) Meanwhile I will continue to play on http://www.friv4online.com/ . It’s entertaining and a great way to kill time while waiting.
Starspawn
Post by Starspawn » Sat Feb 10, 2018 11:23 am
Didnt find a dedicated DIY thread, but did anyone here DIY the Ming Mecca?
Almost done, core works fine, but theres some oddness with control core.
I use a pickit 2 for programming, set up the circuit on breadboard like so:
https://www.arrow.com/en/reference-desi ... bbc31ff202 (emulation device part) and Pickkit 2 2.55 gives me all kinds of good messages of succesfull programming.
End result though is all top leds blinking now and then at the same time.
monads
Post by monads » Tue Apr 17, 2018 10:23 am
This is pretty awesome whomever made and/or if from here!!! I'm sure the World Pack took some time to create!! Just really cool and wish there were more World Packs available to share or purchase.
DSC
Post by DSC » Sat Jun 23, 2018 1:00 am
Goin' custom with two WC's :tu: :tu: :tu: :tu: :tu: :tu:
monads
Post by monads » Sun Jul 01, 2018 3:07 pm
I gotta admit those are pretty sweet DSC!! Do they come with the Mario Mecca World Pack? :hihi:
DSC
Post by DSC » Sun Jul 01, 2018 3:26 pm
ABSOLUTELY!!!!! Finally got them racked and I need to start determining my direction for some custom world packs. Have you worked any up?
monads
Post by monads » Sun Jul 01, 2018 7:13 pm
I worked up this custom 'Halloween' themed World Pack but not nearly as advanced as the Mario one :waah:
DSC
Post by DSC » Sun Jul 01, 2018 7:26 pm
monads wrote:I worked up this custom 'Halloween' themed World Pack but not nearly as advanced as the Mario one :waah:
Nice that is very cool!!!!! I imagine changing color palates makes that a really cool one! That guy who built that Mario World Pack really went nuts. Definitely the gold standard so far!
DSC
Post by DSC » Sun Dec 16, 2018 2:27 pm
Just finished these off with a pretty cool custom module.
One custom module includes preview screen, 3 LFO's with three waveforms each and two envelopes. Also includes bufferred video out's!
Eric the Red
Post by Eric the Red » Wed Dec 26, 2018 9:38 am
Beautiful work
Abandon all hope, ye who wiggle.
Return to “Video Synthesis”
