Linear slew on Wiard 300 series.
Moderators: Kent, grantrichter, carygrace
slow_riot
Post by slow_riot » Sun Feb 22, 2015 4:15 pm
No I prefer smooth tone, it is still very related to the Woggle CV and adds a bit more depth to the patch. Just a fraction, though.
I found syncing using Disturb to be quite difficult to implement, but maybe you can find a way to make it do what you want, or maybe not!
carygrace
If I had two dead rats, I'd give you one
Post by carygrace » Sun Feb 22, 2015 6:24 pm
drumsofd00m wrote: BTW Cary, when I try to clock the WB from the old 311's gate buttons, this only works the first time after making the connection, contrary to clocking from e.g. the Borg LFOs. I.e. I get no woggling from the second push onwards. Is there a way to amend this?
If you mean the Step Clock input, That's because the "gate" on those old controllers is just a voltage going through a momentary on-off switch, which won't work properly with the Woggle Bug clock input. Long story short, basically you need a logic output that goes between 0V and 10V (something like the new gate circuit on the 311C, or a square wave will work too).
You can, however, do it with what you have, with a little patching:
Connect the controller gate out to the Envelator gate in (AR mode), then come out of the Envelator into the WB Step Clock input.
chamomileshark
Post by chamomileshark » Mon Feb 23, 2015 1:13 pm
@ Drums. I got it to work. At least I think I have.
Your patch actually is more interesting that straight portmento so thanks for that!
Key Gear: Wiard 300 Series, EMS VCS3, Frac Modular (Blacet, Wiard, Bananalogue & Synthesis Technology).
Pastoral Music: Mark Ellery Griffiths
Music: https://markgriffiths.bandcamp.com/
Website: https://markellerygriffithsmusic.blogspot.com/
Experimental & IDM: Mark Dalton Griffiths
Music https://markdaltongriffiths.bandcamp.com/
Website:https://markdaltongriffithsmusic.blogspot.com/
Return to “Wiard”
