screws for the blue rack frames?
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Tue Feb 24, 2015 10:16 pm
Sorry - I'm kind of clueless when it comes to stuff like this....
when I got my system, no screws were sent with it, so I 'punted' and used some eurorack screws, which don't fit very well at all.
Can someone possibly link me to some that I can order, that will actually fit the case well? I'd appreciate it.
drumsofd00m
Post by drumsofd00m » Wed Feb 25, 2015 7:27 am
You may now want to refer to The Big R.A.P. (rack assembly pamphlet) that I sent you a month back ;-)
Optimally, you would know which screw diameter AND thread type was used before. Without that, there can be no firm advice on what screws to use. Using a different thread type than before will probably wear out the holes, which *can* mean reduced grip and continuing problems each time you want to swap a module.
I did have that problem, and additionally have one module with slightly off-center mounting holes, so I much prefer Hinton's bars that use through-hole bolts with counter-nuts. You can always use these new bars with the old blue rack ears, so my personal advice is to order one pair of these, or, like I'm planning for my older frame with the messed up self-tapped holes, (quote Graham) "drill the original one(s) out to 4mm, except the end holes which cross a bolt".
plord
Wacky for Wiard Wiggler
Post by plord » Wed Feb 25, 2015 6:12 pm
Nelson, I have a bag of allen-head blue bolts that fit the regulation blue rack frames...but if you've used different threads things may be messed up?
PM me a mailing address and I'll send you a set.
drumsofd00m
Post by drumsofd00m » Wed Feb 25, 2015 6:17 pm
plord wrote:Nelson, I have a bag of allen-head blue bolts that fit the regulation blue rack frames...but if you've used different threads things may be messed up?
And if you do want to go that route I'm offering my own set I got from plord in 2013, so both your frames would be covered.
These are very pretty, but I found the heads too small even with stiff nylon washers underneath; I think the large panels need more surface/ more leverage to pin them down = less flexing when patching.
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Wed Feb 25, 2015 7:12 pm
I was given a link to order these, and the first one I tried to put in broke off in the hole, and I can't get it out. So, I'm wary...(though I wasn't using an allen)
carygrace
If I had two dead rats, I'd give you one
Re: screws for the blue rack frames?
Post by carygrace » Thu Feb 26, 2015 6:47 pm
Nelson Baboon wrote:Sorry - I'm kind of clueless when it comes to stuff like this....
Hi,
I've got some of the correct screws, and if you can email me and let me know how many you need, I can either send you some, or tell you what to buy/where to buy them. It's a US thread and size, not metric.
If you have tried to put the wrong screws in already though, unfortunately, you've probably ruined the tapped holes on the bars. Aluminium is soft, much softer than a steel screw.
ETA: they are 4/40 x 1/4" machine screws.
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Thu Feb 26, 2015 6:54 pm
oh, joy.....well, probably it'd be cheaper to order them here, rather than have you ship them to me. that's lovely if I've ruined the holes though.
Hi,
I've got some of the correct screws, and if you can email me, I can either send you some, or tell you where to buy them. It's a US thread and size, not metric.
carygrace
Post by carygrace » Thu Feb 26, 2015 6:58 pm
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Thu Feb 26, 2015 7:09 pm
Cool. thanks!
carygrace
Post by carygrace » Thu Feb 26, 2015 7:09 pm
Nelson Baboon wrote: that's lovely if I've ruined the holes though.
Hopefully they are OK; it's definitely still worth trying the right screws to see.
If not, please get in touch and I'm sure I can come up with a solution to fix the bars by either re-tapping them or drilling out to a larger size. There are options!
In future, a couple of tips:
1. If a screw doesn't go in easily and smoothly, something is wrong. Don't force it. It's either the wrong screw or the thread is crossed.
2. Be gentle and never over-tighten screws into threaded holes, especially aluminium. Just tight enough so it doesn't come out, but no further.
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Thu Feb 26, 2015 7:10 pm
well, i don't have good common sense when it comes to this stuff. I don't recall forcing them to much, so hopefully it will be ok.
carygrace
Post by carygrace » Thu Feb 26, 2015 7:16 pm
Nelson Baboon wrote:I don't recall forcing them to much, so hopefully it will be ok.
Hope so! Let me know what happens. It really depends how different the threads are on the screws you put in, and I'm afraid I have no idea. Good luck/fingers crossed!
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Thu Feb 26, 2015 7:27 pm
well, I got the modules and the cases, and realized I didn't have screws, so I just used generic eurorack screws. They at least held the modules in...
thesnow
Post by thesnow » Thu Feb 26, 2015 9:54 pm
the Hinton frames are really, really nice and excellent quality, He ships them with plenty of extra hardware to fix your modules in too
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Thu Feb 26, 2015 10:01 pm
thesnow wrote:the Hinton frames are really, really nice and excellent quality, He ships them with plenty of extra hardware to fix your modules in too
but I'm not looking to spend more money because I've ruined the holes here, unless I have to.
carygrace
Post by carygrace » Thu Mar 05, 2015 7:49 pm
Any reason why these won't work? https://www.globalindustrial.com/p/fast ... age-of-100
Don't see why they wouldn't. Not as pretty as round head ones, but they are the right size, so you ought to be fine.
J3RK
Post by J3RK » Fri Mar 06, 2015 12:52 pm
Tacoma Screw http://www.tacomascrew.com has a very good selection of 4/40 screws. They have good prices, are very quick to ship, and I don't think there's a minimum order. I get all of my socket and button cap screws there for my modules, and also rack screws of the same type.
These would be the ones. They also have different finishes, like chrome, and steel, etc. http://www.tacomascrew.com/Products/But ... 25-607-1_2
Here are some socket-cap types, which I think would look cool with a Wiard (though I'd probably go with a non-black type)
http://www.tacomascrew.com/Products/Soc ... 0-204-1_10
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Sun Mar 08, 2015 11:57 am
oh - just saw this. Thanks for that. I already ordered from the link I provided above. $3+ and then $11+ shipping.....ouch.
J3RK wrote:Tacoma Screw http://www.tacomascrew.com has a very good selection of 4/40 screws. They have good prices, are very quick to ship, and I don't think there's a minimum order. I get all of my socket and button cap screws there for my modules, and also rack screws of the same type.
Return to “Wiard”
