Sequantizer weird issue
Moderators: Kent, carygrace, grantrichter
modularfreak
Post by modularfreak » Sun Feb 09, 2020 7:12 pm
When my Sequantizer is attached to a Hinton power supply the quantizer output doesn´t work - no pitch change at all - while the unquantized output works perfectly.
If I use another power supply - either an original Grant Richter or a Blacet stock - everything is fine. Tried different cables, of course as I found out that sometimes pin 2 or pin 3 of the molex connector is used as ground but that doesn´t seem to matter at all.
All other modules connected to the Hinton seem to work as they should. My guess is that something with the ground isn´t as it should but that´s just a guess from an experienced user with less tech background.
What does the quantized output of the Sequantizer expect that other modules don´t care about?
Help is much appreciated.
Graham Hinton
Re: Sequantizer weird issue
Post by Graham Hinton » Sat Mar 07, 2020 8:15 am
Pins 2 and 3 of the Molex are connected together on the distribution.
Blacet power supplies are not grounded (or safe).
What are you connecting it to?
Is there another powered system involved?
You may have a faulty Sequantizer. There are plenty in use with FullPower PSUs.
Do the Transpose, Octave+ and Octave- inputs work?
Aether Machine
Post by Aether Machine » Wed Apr 01, 2020 5:27 am
I had a similar issue with a Waveform City module which worked on a Blacet PS500 but would fail after 45 mins when connected to a Full Power supply, this was fixed urgently (turnaround 1 day) by Cary for a festival performance in 2012 - if that jogs anyone's memory. I recall that a resistor in the digital board needed to be changed to a higher wattage.
Return to “Wiard”
