Live improv performance modules
Live patching, designs, and techniques that push the performance envelope.
dangayle
Post by dangayle » Wed Feb 19, 2020 1:24 pm
Hi all. I'm curious what your favorite modules for live improv performances are. I've basically been going the "Baseck+" route with a Manis Iteritas + Voltage block combo as the heart of my system, a BIA for kicks, a Plaits clone and a DNIPro Dot sequencing three drum tracks on my Bitbox. I swapped my Varigate for Bastl Knit rider, and I'm much happier with it.
I find the Bitbox makes a great tool for live performance, because I can get a second kick, ambient sample, or other sounds going while I transition my other modules for the next section. I might get a second Dot sequencer for it, because it is just so handy.
What other tools do you have that make for great live performances?
ersatzplanet
Synthwerks Design
Re: Live improv performance modules
Post by ersatzplanet » Thu Feb 20, 2020 12:41 am
You are talking about modules to play, not controllers to play other modules, right? If that is the case, the Nebulae is the one I play with the most. A huge range of different sounds and timbres are possible with it.
If you are talking about controllers, I basically make a full line of different ones and I use them all.
-James
dangayle
Post by dangayle » Thu Feb 20, 2020 8:00 pm
I think I meant both. For instance, I have the Voltage Block. Killer for live performance. Or the Bishop's Miscellany, I've been eyeballing that one. For voices, it's to me if you can get a variety of sounds out of it without having to completely re-patch everything.
authorless
Post by authorless » Thu Feb 20, 2020 9:31 pm
Doepfer A-198 ribbon controller.
"Wait a month and buy from a fellow wiggler who's desperate for new modules." - Johnisfaster
"It's oscillators are so precise and lifeless it's actually a digital modelling analog synth." - nadafarms
blw
Post by blw » Mon Mar 02, 2020 1:59 pm
I get a lot out of a couple of Soundmachine LS-1’s and Mutable Ears for control. I usually use 1010 bitbox/toolbox into a Magneto and Modcan Dual Delay for drums or ambient textures, and then work with a few modules for a lead sound. That’s about the amount of stuff I can get my head around in a live set, and the 1010 modules’ memories help a ton to vary things up.
ZargZorg
Post by ZargZorg » Mon Mar 09, 2020 9:03 pm
Rene MK1 or Mk2. The touch controller is butter to use live
Return to “Play Out! Performance Modulars”
