My AM8060 has resonance when the knob is at zero [Resolved]
Discussion and support for the AMSynths range of analog synthesizer modules.
Moderators: Kent, emuarc
meta
Post by meta » Fri Sep 01, 2017 9:29 pm
My AM8060 (purchased direct from AMSynths a year or so back) has always had a good bit of resonance, even with the resonance knob at minimum. Its "zero" resonance is equivalent to my Ripples' 11:00 resonance.
My AM8060's resonance is strong enough to cause clipping even at 10:30.
Is this normal, or does my AM8060 need calibration/repair?
Here's a video showing the effect on the O'Tool's spectrum analyzer:
Top: Ripples
Bottom: AM8060
Saw wave is from A-111-1. VCF frequency is being swept slowly by a Make Noise Function. Both filters direct into O'Tool.
meta
Post by meta » Wed Sep 06, 2017 4:02 pm
OK, looking at the project notes on the AMSynths site, I see there is supposed to be a trimpot to adjust the resonance range. I'll pull my AM8060 out and see if it helps to adjust that.
meta
Post by meta » Wed Sep 20, 2017 8:53 am
Yep, just needed to adjust the trimpot to full CCW. Still seems to have a tad more res than Ripples, but it's close now.
Return to “AMSynths”
