Alyseum MS-812
Moderators: Kent, AlyseumSupport
- sylvainmoreau
- sylvainmoreau
for those sad folks who bought this crappy module.. do you know why sending midi to control the CV jacks is so terrible ? values you play have delay and jumps.
i use ES-3 with reaktor block sending via ADAT the values to es3 jacks out it's very reactive and fluid.
same reaktor bloc module but now i use the MIDI out block to send MIDI to copperlan to ms812 to control the Modifier A out for CV1.
i could see in copperlan the slider moving poorly.. it's not a display it's how it works. the CV coming out from the 812 is unusable because so offset and sound like jumps in values.
or i do something wrong ?
- Donderdag
Mine works great too. Send them a message. They've been quick to get back to me.sylvainmoreau wrote:for those sad folks who bought this crappy module.. do you know why sending midi to control the CV jacks is so terrible ? values you play have delay and jumps.
---------------------------Venetian Snares wrote:I wanted it to sound like a giant hovering boulder on fire
Seize the Carp
Stuff for sale
My Soundcloud
- solipsvs
Re: Alyseum MS-812
i love my 4 ms-812, they work amazing. the rest of my alyseum modules (6 al-88c) on the CL network are working great too. im very happy with my network
Re: Alyseum MS-812
Do any of you happen to have the 64bit version of the windows vst, can't find it on any of my drives :(
- solipsvs
Re: Alyseum MS-812
vst? not aware of any vst. what are you talking about? i hope its something i dont know about yet
Re: Alyseum MS-812
https://sourceforge.net/projects/ms812proxy/files/
Here they are, but 32 bit version and jBridge crashes unfortunately for 64bit emulation.
Otherwise, anyone succeeded sendin continuous midi value from max for live to vMidi channels of copperlan ?
I can't manage to make it work.
- solipsvs
Re: Alyseum MS-812
oh that. can you get that to work at all? what host and how?
Re: Alyseum MS-812
32bit host i believe, phil sent me the 64 bit version 5-6 years ago but i can't find it anymore on any of my drives
- solipsvs
Re: Alyseum MS-812
my 32 bit hosts dont recognize it as a plugin. i would like the 64 bit version if anybody has it too.
Re: Alyseum MS-812
I tried to contact phil from copperlan but i didn't get any answer sor far.
There is the source code on sourceforge, but the repository is unfortunately empty... so in order to compile it in 64bit will have to copy the file one by one i guess... Don't know if I'll do so...
Re: Alyseum MS-812
So I managed to download the source files writing script in js but unfortunately the source code requires VST2 SDK of Steinberg which has been removed from their website so i cannot build the plugin.
EDIT: I managed to find an older version of the SDK trough their "secret" archive. Now there is 316 compilation error and I never did C++ so I don't know guys, I'm gonna stop for today maybe I'll try again but this is not looking good.
RE-EDIT: Did a try with VS2008 instead of VS2019 I now have one error left with a library included in the source code which is corrupted and no way to find it elsewhere, it seems that pretty much sums it up :(
Re: Alyseum MS-812
Didn't manage to build it but look what I found on my old computer
https://sourceforge.net/projects/ms812p ... st2/files/
- solipsvs
Re: Alyseum MS-812
is it 32 or 64 bit? thanks for the share!nofuture wrote: ↑Sat Apr 04, 2020 7:40 amDidn't manage to build it but look what I found on my old computer
Re: Alyseum MS-812
It's the 64bit VST2
The 32bit VST2 is hosted on sourceforge as well you can find the link in previous pages of the discussion.
- solipsvs
Re: Alyseum MS-812
wow i didnt realize how steppy digital oscillators can be on the v/oct input... ill definitely be needing an analog scaler and offset to avoid steps. but once you do that its great.
