MS-4 questions
Discussion and support for Alyseum products.
Moderators: Kent, AlyseumSupport
rozzbud
MS-4 questions
Post by rozzbud » Wed Dec 04, 2013 7:55 am
hi,
is it a standalone midi to copperlan converter?
Can i go from a hardware 32ch midi sequencer to 2xms-4 to 2xms-812 without a computer?
And is it possible to sequential switch (like a seqsquared) the midi output without other modules?
Automate a midi ch to switch between 4 outputs on ms-812 for instance.
thanks
alyseum
Post by alyseum » Wed Dec 04, 2013 8:24 am
Hi rozzbud
Yes the MS-4 is also a MIDI in to CopperLan converter; like the AL-22, but with a single MIDI In.
Yes, with 2 MS4 or a single AL-22 and you have 32 MIDI Ch :razz:
About the seqsquared, it's not the same function, it's not possible to switch differents MIDI CH to differents output in real time
Regards
rozzbud
Post by rozzbud » Fri Dec 06, 2013 10:08 am
if i understand correctly i have to use copperlan manager on pc for al-22 whereas ms-4 comes with programs per midi channel.
So ms-4 needs no computer at all?
alyseum
Post by alyseum » Wed Jan 01, 2014 12:41 pm
Yes and No, You need the computer to established they connections or programming the setting for the inputs CV.
After, for live and performance, you can use the MS-4 without computer.
Kashif
Post by Kashif » Mon Feb 02, 2015 11:56 pm
This is extremely pleasant and average post....you shook posting it....thanks a ton for posting it..!! :woah: :woah: :woah:
Johni
Return to “Alyseum ”
